ebay projectors - Exterior Forum
ebay projectors
Friday, March 04, 2011 2:23 PM
If i buy the ebay projectors, would i be able to fit the stock mounting brackets to them with some DIYing in order to get them to fit like stock?
Re: ebay projectors
Friday, March 04, 2011 2:54 PM
should fil like stock anyway...
Re: ebay projectors
Friday, March 04, 2011 3:19 PM
I've heard ALOT about them fitting horribly.
Re: ebay projectors
Friday, March 04, 2011 3:23 PM
i did that.. but then i ended up enlarging the mounting holes and using washers so i was able to adjust them properly to fit. Iv never seen those versions before with the shroud around the projector.
Re: ebay projectors
Friday, March 04, 2011 6:39 PM
Does the light itself look similar to yours?
Re: ebay projectors
Saturday, March 05, 2011 7:02 AM
i had those on my 98 they fit fine, the light output was horrible with any bulbs. i may as well been driving with just parking lamps on
Re: ebay projectors
Saturday, March 05, 2011 7:11 AM
Rich Grayo Jr. wrote:should fil like stock anyway...
The back of the projector housing will hit on the core support, making them point up. You will need to dent it in a little.
azncav wrote:i did that.. but then i ended up enlarging the mounting holes and using washers so i was able to adjust them properly to fit. Iv never seen those versions before with the shroud around the projector.
I have the same ones, but black housing. They have been around for a while.
DJ Beefy wrote:i had those on my 98 they fit fine, the light output was horrible with any bulbs. i may as well been driving with just parking lamps on
That's why you don't run halogen bulbs in a projector housing. H.I.D.'s will do wonders.
Here is a pic from when I first put them on. The rear of the housings hit the core support and push them down into the bumper.
Dent it in a little right above where the back of the housing sits and they will drop right in and aim properly. The cutoff isn't horrible, but could use some improvement. This is the same projectors with a 35W DDM 6K kit.
Edited 1 time(s). Last edited Saturday, March 05, 2011 7:17 AM
Re: ebay projectors
Saturday, March 05, 2011 7:14 AM
Thanks for the feedback. Ill keep these lights in mind.
Re: ebay projectors
Saturday, March 05, 2011 7:20 AM
Evan Murray wrote:Thanks for the feedback. Ill keep these lights in mind.
Added pics to my post to help explain what I was talking about.
Re: ebay projectors
Saturday, March 05, 2011 11:32 AM
fitment and output with the aftermarket ones leaves a lot to be desired. i have heard of people modding facotry brackets to help, but honestly, I would stay away from these. even with HID, the output isnt that great.
