i was thinking of using red pearl in my clear coat but would it look good or would flake look better?
it's basically all in personal taste. I think either would look good, but I like pearl more.
i'm most likely going with pearl
I'd go pearl for the most part... but throw in a little micro-flake in the same red for that extra Ooophff in the sun. (Old Hot Rodder trick)
My Car Domain
you do not mix pearl in the clear
what you want to use is a mid-coat clear mixed with the pearl
explain what the pearl is going over i can help more
can i haz bondo
big daddy wrote:you do not mix pearl in the clear
the paint is going over gm glossy black i don't want alot of red i just want to see it enough to know its there. so mid coat would be paint,clear with pearl then clear???
no, you mix the pearl in with the mid coat clear it acts like a base coat, then clear coat
can i haz bondo
big daddy wrote:no, you mix the pearl in with the mid coat clear it acts like a base coat, then clear coat
sorry agin but do you mean mix the pearl with the color then clear coat it?
no, a midcoat is like basicaly clear coat, you mix your pearl in the midcoat and put it on top of the base coat. Then you clear over that. Its basicaly just a clear substance that your able to put pearl in it and mix it. They also call the mid-coat stuff called "blender". hopefuly that helps out!
BroughtDownKustomz (Blue Ace) wrote:no, a midcoat is like basicaly clear coat, you mix your pearl in the midcoat and put it on top of the base coat. Then you clear over that. Its basicaly just a clear substance that your able to put pearl in it and mix it. They also call the mid-coat stuff called "blender". hopefuly that helps out!
yes that dose thank you alot
