Locked Eco Reflash - Tuning Forum
Locked Eco Reflash
Thursday, May 17, 2007 11:33 PM
Just a quick question. Can you read the reflash and save the tune file?? And if yes, can you do a write entire on another Eco with that file, and make it so it's not locked anymore?
2000 Camaro V6.
| SLP Loudmouth | CAI Intake | HID's |
Re: Locked Eco Reflash
Friday, May 18, 2007 4:36 AM
Yes, you can read it, no, you can't write it.
And its not the act of reading or writing that its locked, its locked in such a way that HPT cannot determine what the calibration or vehicle it is for.
Friday, May 18, 2007 9:46 AM
Ohhhhh ok I got ya....
Thanks
2000 Camaro V6.
Friday, May 18, 2007 9:53 AM
nice try
14.083 @ 99.746 mph GMPP s/c intercooled on drag radials.
Friday, May 18, 2007 10:01 AM
Shifted wrote:Yes, you can read it, no, you can't write it.
ok, i'm showing off my stupidity here for a second regarding HPT
What do you mean by "you can read it?" What exactly will HPT read? Would I be able to use HPT to data log when I make passes down the track? or will HPT not show me anything? I'm completely confused on that aspect.
Friday, May 18, 2007 10:02 AM
since HPT can't determine what car you have, it certainly won't be able to read any of your sensors and therefore won't be able to log anything
Friday, May 18, 2007 12:26 PM
It can download the BIN file, but it can't determine what the layout of the BIN file is. All it can do is convert it to a .HPT file and say "contact support'
Friday, May 18, 2007 8:56 PM
Actually you can datalog cars using the eco GMSC reflash with HPtuners.
15.3 @ 89.97mph - '01 SFGT
'98 Acura 1.6EL Sport 5M Y7/Y8 mini me
Saturday, May 19, 2007 12:53 AM
Yeah, you can datalog with the eco reflash (as said above), to give some concrete examples, here's some: the ones you can already see of course (Speed, RPM, ECT, Fuel Level), but also quite a few more (in no particular order)...tps, timing advance, knock retard, afr commanded, map, iat, O2 voltage, inj. pulse width, injector duty cycle, short and long term fuel trims, fuel trim cell, trans fluid temp, trans current gear, and a bunch of other stuff. You can also hook up widebands to it and even make custom gauges based on calculations of other guages (such as how the injector duty cycle is calculated). You can also view the information on guages, charts, or histograms (which you can customize all of these).
