Reflash to custom tune. - Tuning Forum
Wednesday, December 23, 2009 10:19 AM
I have a 2002 sunfire gm sc'd eco and I'm growing tired of the gm reflash.
What kind of gains (hp/tq) could I expect from a mild reliable tune? Reliability is my main concern. (Car has 2.25 headerback exhaust, AEM cai)
Do I have to purchase a wideband gauge for this to work? (wondering cause the gauge is expensive, and I already have 3 other gauges intsalled, gauge pod is maxed out)
If I later install a 3.1 pulley with Heat exchanger, will I have to get it re-tuned?
General cost range after it's all said and done? Is it even worth it for the minor engine mods that I have?
Thanks for your time.
Re: Reflash to custom tune.
Wednesday, December 23, 2009 9:09 PM
I dont see that you would get much of a gain in reliability, GM runs things rich to keep you safe, if it wasnt, they wouldnt warranty it. You will get a power gain in leaning things out instead of choking it with fuel. To tune you will need a wideband, this can be done either by you putting in one or taking it someplace and having them use a sniffer, but thats only effective if your not running a cat.
Most tunes will run you at least 150, prob several hundred if done by a good shop.
Thursday, December 24, 2009 3:11 AM
There was a post where someone dynoed a GM reflash car and then a custom tune. Power was a nice difference. Should be no realiable difference if the tune done right.
Thursday, December 24, 2009 4:17 AM
Reliability should actually be better. The datalogs I have here on my laptop show a crapload of knock retard with the GM reflash.
Monday, January 04, 2010 3:28 AM
If you aren't going to change pulleys there isn't much reason to change the tune for what it will cost.
This is the shop that did my tune. http://www.appalachianperformance.com
most shops I have run into looking for a tune start at 500.00
GM TUNE vs Custom TUNE
Monday, January 04, 2010 11:19 AM
Jbdy04 wrote:If you aren't going to change pulleys there isn't much reason to change the tune for what it will cost.
That isn't necessarily true.
I dyno'ed 196 whp on a mustang dyno on a custom tune. Guys running smaller pulleys with the reflash have made less power than that on the same dyno.
Tuesday, January 05, 2010 10:54 AM
my car on stock pulley and stock reflash made 215whp that was on a dyno jet and I know they read higher then mustang dyno's so unless you just want a custom tune to me the means doesn't justify the end. Just food for thought.
Sunday, January 10, 2010 12:53 PM
Thanks for the advice guys. I am going to hold off on a custom tune and stick with the reflash for now.
