I noticed that only my pass. side seat slides forward when its leaned forward and my drives seat doesn't. Is this the way they were made?
1998 Sunfire, 2.2L auto
another mind blowing gm invention for you
I use it to my advantage, just tell passengers they all have to load up on the other side.
Words that you can't use in modding: Finished, Perfect, Cheap.
[quote=ßãggéÐÇåv98 (Ûñqùðtäߣè Øñé)]another mind blowing gm invention for you
i've never seen any coupe that didn't do that. its so the passangers can flip the little lever and have enough room. if it didn't slide forward, they'd still have to crawl over the seat.
GO PATS!!!
Both mine slide forwrd even with it tilted forward........aftermarket seats but they are on the stock rails/sliders.
I have one true love in my life...And my girlfriend sits next to me in it
Derek724 wrote:I use it to my advantage, just tell passengers they all have to load up on the other side.
Bingo, that's what I do too. Except my girl always insists on getting in on the driver's side anyway, haha.
your girl should be riding shotgun...regardless of who else is in the car
GO PATS!!!
i think he means only with using the arm on the side of the seat, not the one underneath.....just pull the lever and it automacically unlocks and slides
_______________________________________________________
J-body.org Join date: Monday, January 21, 2002
AIM & Y!: COGcaviZ24
He is talking about the Easy Entry that is on the passenger seat only. Unless you have modified your drivers seat, GM only put this feature on the passenger seat. It is activated when you lift up on the little handle on the lower backside of the seat. It will move the seat all the way to the front of the rails. When the back of the seat is put back to it's normal up right position, you can then push the seat back to it's original position.
98 Z24
RIP Specks
^thats what i mean
Even the Club Cab Ram is like that, my Uncle's 1996 Ram and my Buddy's 1998 Ram both only the Passenger side of the bench slide forward, the driver's side does no such thing.
Yella02-I promise I will return to you in one piece and this will stay up until I am safely home
