DJ MIKE BARR wrote:Not really much machine work to tghe engine but had to make a custom block off plate...yes its a fake tip all razzis are lol...and yes I've cleaned up the engine bay..computer is in the cabin...the strap was just in there for the test drive...I'm now using the lsj spark coil cover cutg so that the l61 coils work...the will be gone once I figure out my msd problems
BuiltNBoosted wrote:DJ MIKE BARR wrote:Not really much machine work to tghe engine but had to make a custom block off plate...yes its a fake tip all razzis are lol...and yes I've cleaned up the engine bay..computer is in the cabin...the strap was just in there for the test drive...I'm now using the lsj spark coil cover cutg so that the l61 coils work...the will be gone once I figure out my msd problems
i gotcha. and not all tips on the razzi are fake. mine were not fake i plan on running the same valve cover with the stock l61 coil pack as well. where did you cut or grind to get the coil pack to fit? did you modify the coil pack or the valve cover or both? i have a cover plate as well so the top of my coil pack is already off. looks like i need to modify the black plastic on the coil pack.
Ben D(Silver J on 1Nines) wrote:BuiltNBoosted wrote:DJ MIKE BARR wrote:Not really much machine work to tghe engine but had to make a custom block off plate...yes its a fake tip all razzis are lol...and yes I've cleaned up the engine bay..computer is in the cabin...the strap was just in there for the test drive...I'm now using the lsj spark coil cover cutg so that the l61 coils work...the will be gone once I figure out my msd problems
it was pretty easy, just grind out where the metal sleeves are that the stock bolts go through.. this is the only part that sticks out off of the coil pack... then i just cut the plate with a dremel and it fit great!
z yaaaa wrote:i am a fan of that valve cover more than the L61 for some reason...
