Not all JDM parts are useless and overrated :) - Photos & Media Forum
Monday, October 08, 2007 8:50 AM
Its no secret I've never liked the JDM fad...... awesome your oil cap says oil in japanesse it rates right up there with Altezzas and stickers
but after seeing this picture of the GTC I'm glad to have the extra clearance of the Toyo fenders... I don't know if those tires and or stock fenders would have survived through the day running 235's LOL
But anyways yesterday was the first time out with some new parts, heres a couple more pics....
I was doing some sick Tokyo Drifting through the last turn LOL
hey if you don't hit cones your either a pro.... or your not pushing it enough
Re: Not all JDM parts are useless and overrated :)
Monday, October 08, 2007 8:57 AM
holy dipping lol nice pics, so everything is running good with the GTC?
Monday, October 08, 2007 8:59 AM
what class were u runnin? stx? or just crossin out the s on sts? how'd the brakes feel? lookin good.
_______________________________________________________________________
my carDomain updated 9/2/07 I've got premium. Yes I do. I've got premium. How 'bout you?
Monday, October 08, 2007 9:04 AM
for the most part all is well. it takes some getting used to with the new stuff. these tires are far better the the Neo Gen's, the rear end has a lot more grip then it used to. I'm gonna mess with Koni settings and possibly try going back with the Addco rear bar to see if I can make the car want to rotate a little more rather then push. but yeah alot more traction, more responsive, and I haven't gotten used to the fact that with the willwoods I don't have to be on the brakes nearly as early.
Car is doing great, I still need some improvement and relearn the car (which wont happen with one more event left for the year
Monday, October 08, 2007 9:07 AM
His car profiles says he has a hi flow cat which would put him into STX
Monday, October 08, 2007 9:22 AM
profile is not up to date but the bigger diameter brakes, tires wider then 225's, and high flow cat = STX
Monday, October 08, 2007 9:29 AM
i've really liked your car since its been redone... i'd love to see some dark tint on it to blacken out the windows and match the rims a bit. great car and i love the stockish yet not stockish type look of it, lol. looks good taking those corners like a champ. well done.
Monday, October 08, 2007 9:34 AM
I love it. i want a base 03 or newer base model any one want to trade. that just hot. GTC ftw.
Monday, October 08, 2007 9:46 AM
my car didn't want to rotate very well this weekend either at the event i was running at. i softened the konis up front, stiffened up the rear, and dropped the front tire pressures a few psi and it made a world of difference.
car's looking great!
Monday, October 08, 2007 9:50 AM
I have the koni reds and am wondering how do you adjust the ride? like softer or harder?
Monday, October 08, 2007 10:02 AM
strat81 wrote:my car didn't want to rotate very well this weekend either at the event i was running at. i softened the konis up front, stiffened up the rear, and dropped the front tire pressures a few psi and it made a world of difference.
making the suspension stiffer and or the tire pressures higher on an end will make that end slide more. I don't like messing with tire pressures much becasue I have them set to where the tires wont roll onto the sidewall, they will go right up to the edge of the tread but wont touch the sidewall. I'm still gonna mess with the Koni's a bit and depending on results the Addco bar is definetly make a big difference. there is a pretty big size and car feel difference form the Eibach to Addco rear bar. Luckily I have both sitting around so I can do as I please LOL
Monday, October 08, 2007 10:05 AM
i never had a problem with my 235's and stock fenders
good pictures!
Monday, October 08, 2007 10:09 AM
paul eccles wrote:i've really liked your car since its been redone... i'd love to see some dark tint on it to blacken out the windows and match the rims a bit. great car and i love the stockish yet not stockish type look of it, lol. looks good taking those corners like a champ. well done.
thanks but I'm not considering with making aything on the car match better LOL
NightmaresCavy wrote:I love it. i want a base 03 or newer base model any one want to trade. that just hot. GTC ftw.
thanks
megatron wrote:I have the koni reds and am wondering how do you adjust the ride? like softer or harder?
not sure what your asking... if its what your adjusting its how the firm the struts are, if it how to adjust it you need to remove them from the car and I beleiev compress them all the way and then twist one way or the other (which is the reason they don't make them anymore, with the yellows you just pop the hood/trunk and twist a knob)
Monday, October 08, 2007 10:15 AM
you said that stiffening up the suspension will make the car slide and then mention going to a larger sway bar...
i'm just telling you what worked for me this weekend. i didn't say to add pressure, merely suggested running lower pressure in the front tires to help them grip a bit better than the rears. also, softening the konis more in the fronts helped the car rotate better as well.
good luck setting up the car.
Monday, October 08, 2007 10:16 AM
looks like you had fun.
i got your text message. i would have come out but the wife didn't get home from work until damn near 5am. so i let her sleep all day and watched the kids. no way was i gonna try to take both of them by myself out there. maybe next time.
SO EVERYTHING!
Monday, October 08, 2007 10:20 AM
I said stiffening up the suspension on an end will make that end slide. not the car.
I didn't say anything about adding pressure to the tires ether
Thanks for the advise and all but I've done this enough to know I'm doing
leaving everything up to the struts and running them rock hard isn't the route I'd go when I can swap in the other sway bar and run the struts at a level where they will absorb bumps rather then hoping over them.
Monday, October 08, 2007 10:25 AM
car is lookin good as always man!!!!!!!!!
I NEED a 97-99 LD9 engine harness for an auto.PM if u hav info.!!
Monday, October 08, 2007 10:33 AM
damn, wish I had known about this earlier..... Tom didnt say anything till AFTER the event was over.....
Whens the next event? I keep forgetting to look it up. SCCA or WIAA? My dad wants to bring the Fiero out one last time, before it goes in for the engine swap.
SPD RCR Z - '02 Z24 420whp
SLO GOAT - '04 GTO 305whp
W41 BOI - '78 Buick Opel Isuzu W41 Swap
Monday, October 08, 2007 10:34 AM
This was WAI, SCCA's last event is this coming Sunday I believe
Monday, October 08, 2007 1:22 PM
Needs Toyo tails now.
Ha.
Monday, October 08, 2007 1:35 PM
The fenders themselves (side markers are retarded), trunk liner, and tails are the only Toyo parts I don't hate LOL
Monday, October 08, 2007 3:08 PM
Darkstars wrote:The fenders themselves (side markers are retarded), trunk liner, and tails are the only Toyo parts I don't hate LOL
So you hate my front bumper...even though it's a knockoff. lol
Lookin good dude, that is something I would never do, just really don't feel like sacrificing my front bumper for a fun afternoon. I gotta come watch though. It looks like a ton of fun just to be there.
Edited 1 time(s). Last edited Monday, October 08, 2007 3:09 PM
Monday, October 08, 2007 6:31 PM
I love my fenders, marker lights, taillights, power steering cap, and fuse box cover.
go eff yourself!
BeardLife / Club Awesome Reject Blog
Monday, October 08, 2007 6:36 PM
hey you never know when a little japanesse man is gonna pop out of nowhere and need to know which cap is for power steering and which fuses are which
Monday, October 08, 2007 6:41 PM
