Whiteboy? anyone? can anyone make one? im looking for a crystal clear dome light lens/cover for my cavalier that will snap right into place like a stock one... i painted the white part on the inside of the dome light around the bulbs and now im lookin for the clear lens to top it off
i know someone out there has the ability to make this
someones gotta be able to do this...
i thought the dome light cover was already clear lol
haha i was gunna say that but didnt want to be a dick.
its like the headlights...its not crystal clear like a window
that doesnt sound easy to make
i figure if someone can make a clear lens for a headlight then a clear lens for the dome light should be able to be done
Clear lens for the headlight is a bit easier in terms of design. The dome light has those little tabs that would need to be figured out. Headlight lenses, as far as I can see, don't.
cool! you will be able to see a fugly light blub and socket inside!
wow that is gonna look good!
i do do i?
you folckin moron.. clear? is it gonna look good?
the done light in the 96 Z24 ( not sure what other years/models had this) has a 3 bulb dome light with a white and chrome(not real chrome just reflective like headlights) housing
. it has 2 bulbs for the front ( passenger and driver) and 1 for the back.. it also has 2 buttons mounted on the roof...one controls the passenger reading light..the other controls the driver side reading light
i painted the housing and left the chrome ...it looks nice as it is...i think it would look awesome with a clear lens on it
lol i have a z24 96-- too i didnt think when u got a z24 u got a cool different kind of headlight too?.. lol arent they all the same? only thing i can think of is sand it and buff the original one thats only way i can see to get it halfway clear
no im gonna make it clear by fabricating a whole new piece.... i thought about it today and im just going to make my own out of lexan....ill post pics when its done.....its gonna take alot of heating up the lexan on the oven...and ill probably ruin a few pieces before i get it to do what i want it to
If you want to make a clear lens, I can.
Here's the way i go about it. Its a little more work, but very hard to screw up.
Get 2 pieces of a HARD wood, with no resins, paint, or stains on it or in it.
Shape those pieces to the same contours of your stock lens. 1 piece for the inner design of the lens, the other for the top of the lens.
The more accurate you make these, the better the finished product. So if you want some sort of design to them, now would be the best time to incorporate it.
After your all set on how you want it, Make sure its sanded smooth, and i mean very smooth, so you wont get wood grain grooves in the plastic. Put a thin, even layer of Lard on both peices. This will you remove the blocks when your done
Now for the heat and press:
Get your 2 blocks and sheet or your choice of plastic. I usually use optix Acrylic, 1/8th inch thick. Make sure to pull the paper protective sheet before heating up.
Now if you dont have a press and heat pad, You can use a heat gun and a few cinder blocks, a flat cement floor, and a heavy person.
Place the lower block of wood on the flat ground, Carved shape facing up. Now place a piece of plastic on top and start heating it up slowly with a heat gun. The more even the heat, and the slower you go, less chance of color distortion and bubbles. When the plastic just starts to bend, Put the other block on top with the carved part facing down, onto the plastic. Keep heating it. A second person might be helpfull. Now start putting weight on to the blocks, slowly, not to much to quick. The more the plastic flows outward around the lower block, the better the overall piece will be. Its taking shape. When you get to a point where its at a thickness you want, stop adding weight, and lower the heat. That will prevent it from going farther. turn the heat off completely, and let it cool a bit. As soon as you can touch it, without burning your self, You can pull the blocks off both sides.
Let it cool off, clean up any residue, and drink a beer.
http://members.rankmyride.com/djtorello
sounds good man i think ill give that a try when i get some free time
haha it might just be me but thats the funniest thing ive heard in awhile lol. the unlimited possibilities that come with those objects hahaha
i have an idea to make a stock one clear let me see if i can get one and if it works just pay the shipping.
The Other Matt wrote:ok lemme know
nope it didn't work sorry
