Im starting to tear down my car thins winter...and im gunna take the dash apart..well while i have it all apart i want to paint it....my car is cayenne red.....should i paint it that color or a regular red seems how all of the after market stuff is a red and black.....like seats steering wheels all that stuff????? also how should i paint it should i rattle can it or do it with an air gun????And i dont plan on doing the whole dash...Like some iv seen...if you could help me out Thanks Sean
if u can do it with gun it would b better cuz the paint and clear is more durable in my opinion but if u cant do it with a gun then rattle turns out good if its prepped right. and as far as the color goes if u use a air gun u can get the paint code and match it , if u use rattle u can get it close but not perfect, it all wat u want and how much work u want to put in to it.
I rattle canned mine, using good prep it has held up VERY well in the 2.5 years since I painted it.. The only place it's rubbing off is right under the radio where drink cups and such have rubbed on it quite a bit, just use lights coats and clear the hell out of it.. you can get a pretty good looking piece with good prep work and patience. Obviously if you have access to a gun, that is the proper way to go, but a rattle can job would look just as good.
As far as the color, I would color match it to other interior items if you have to pick. It will look off if you have different shades of red in there.
OhForKavy wrote:I rattle canned mine, using good prep it has held up VERY well in the 2.5 years since I painted it.. The only place it's rubbing off is right under the radio where drink cups and such have rubbed on it quite a bit, just use lights coats and clear the hell out of it.. you can get a pretty good looking piece with good prep work and patience. Obviously if you have access to a gun, that is the proper way to go, but a rattle can job would look just as good.
I have done the rattle can approch too. I am still in progress with my interior but I sanded it down to make it smooth and then hit it with a primer prior to using a metalic silver to give it that shine. Most of my dash (sunfire swap of course) is originally black and the silver makes a great accent.
Like most people on here would tell you, it all depends on what you want to do. Rattle cans are the easy way but if you have the money to do so, go HVLP.
I used a rattle can it came out good i find, but i think its fading, but i did not clear coat it.
98 Sunfire
Sunfire92 wrote:I used a rattle can it came out good i find, but i think its fading, but i did not clear coat it.
Clear coat is your friend, it keeps the shiny look and protects it from fading, peeling, chipping.
FOR SALE
First step when I started on my dash was, before anything CLEAN it with wax and grease remover
Second step..sand with 36 grit, once the texture is gone, go with 80 grit, then 180 grit, then 320.
After all that, I used some dupli-color raddle can 2K high build primer, and did 3 coats, then guide coated it, blocked with 400 grit, guide coated again and blocked with 800 grit, wet sanded on both of coarse, then depending on how it looks, either went on or sprayed a few more coats of primer and repeated...
After is it all good, CLEAN it with wax and grease remover
Now, your ready to spray your base (color) coat. I used dupli-color truck & SUV paint, used 3-4 coats
Next step was clear coat...I used dulpli-color truck & SUV clear coat as well, and cleared the hell out of it...i cant remember exactly, but I know there were at least like 10 coats of clear on each piece. I reccommend for proper adhesion of the clear to color sand it between each 3 coats of clear (Just a suggestion, someone correct me if I am wrong, but I beleive it is needed with automotive paint as well out of an HVLP gun past 3 or 4 coats)
Last would be color sanding/buffing if needed....
Hope this helps! I can try to get pics if you would like..just all depends on if I can get a camera or not.
"Hondas are like tampons, every pussy has one!!!"
