overfilled my transmission fluid - Transmission Forum
Monday, May 31, 2010 9:26 PM
Earlier today I changed my fluid and filter. In the haynes manual it told me I needed 7 qts to fill it back up. So I did that only to find out I overfilled it because I only needed 4 cause I didn't do a complete flush I only plan on driving it like this until after work tomorrow so I can drain some of it out. Will it do any damage to my transmission if I drive it temporarily?
www.gmofhouston.com
Re: overfilled my transmission fluid
Tuesday, June 01, 2010 8:12 AM
Worst that could happen is you blow a seal or foam the fluid up I wouldn't drive it till you fix that
I just cant drive 55
Tuesday, June 01, 2010 3:19 PM
I plan on draining some out later today once its cools down outside. I couldn't help it I had no choice in driving my car to work today.
www.gmofhouston.com
Friday, June 04, 2010 8:20 PM
i would use a mighty vac and pull it out there is no guarantee how much you are going to drop if you plan on loosening the pan and draining some
Erik Packard
Friday, June 04, 2010 8:56 PM
Yea it's been a pain but I finally got the level right.
www.gmofhouston.com
