ecotec Oil feed help !!!!!!!!!!!!!!!!!! - Boost Forum
Wednesday, December 28, 2005 3:50 PM
where can i tap into to hook up my feed line
Re: ecotec Oil feed help !!!!!!!!!!!!!!!!!!
Wednesday, December 28, 2005 4:12 PM
You can have a Y pipe made that will go where the stock oil pressure sending unit is, and put the sneding unit and your oil feed on it. That is located on the front of the motor just below the intake manifold.
Wednesday, December 28, 2005 4:50 PM
Or you can tap into the girdle near the oil pan. I just learned that one myself! Thanks Brandoson!
Saab Turbo Project.... Nearing completion.
Wednesday, December 28, 2005 6:41 PM
Sasuke wrote:Or you can tap into the girdle near the oil pan. I just learned that one myself! Thanks Brandoson!
not return.. feed
I used a port on the head under the intake manifold, Accel makes an adaptor for it
LE61T PTE6262 Powered
Wednesday, December 28, 2005 6:56 PM
use the port on the head its the easiest to get to
Wednesday, December 28, 2005 7:05 PM
^^^^^^ Oops!!! My mistake!!!
Wednesday, December 28, 2005 7:10 PM
This has been posted numerous times....
a search for "ecotec oil feed" came up with lots of listings with pictures and descriptions...
This is a picture of where I did mine. I suggest using the one to the right of it because it is easier.
The fitting is 1/8" NPT to M12 x 1.75 I dont know the autometer part number off hand though. Its in those threads if you search.
"Growing old is mandatory. Growing up? Definitely optional."
Wednesday, December 28, 2005 7:42 PM
yea i used 1 of the 3 bolts under the intake manifold the part number for that is 1
05-2277 or
105-2278
it is super easy to use 1 from the intakemanifold
Wednesday, December 28, 2005 9:22 PM
with the 1 brandon used , you dont really have to remove anything big
allthough he did have to modify the egr block off plate , but there is another fitting in the head in that same area where you dont have to modify anything
and that is the spot id recomend , its the easiest to get to
only other easy 1 is the 1's under the exhaust manifold in the block , since youll have the exhaust off anyway
Sunday, April 16, 2006 6:34 PM
i have a 2006 pontiac solstice rear wheel drive can i get oil from block on header side of block , of oil feed been trying to pull up pic ,will not cme up
Sunday, April 16, 2006 9:25 PM
umm..........on your 2.4 the oil feeds will be on the back of your motor........close to firewall. there may be 1-2-3 oil spots on the exhaust side, they will be under the manifold......i havent had to much experience with the 2.4 as it wasnt in any j-bodys
*************Yea i spell liek wrong get over it*****************
** If i write in caps its cause im @ work and i can only write in caps cause the keyboard is a retarded CAPS only keyboard.**
