Where's the damn RPM wire???? - Boost Forum
Thursday, March 10, 2005 1:45 PM
Can someone please tell me where the hell the rpm wire is and color on the 01 harness for the pcm. I wired my safc2 up last nite but thats the only one I couldnt find in the wiring diagram. And no I didnt drive it like that.
Re: Where's the damn RPM wire????
Thursday, March 10, 2005 2:15 PM
There is a tach lead in the fuse box right above the battery there... you can't miss it. Read the fuse box cover and you'll see it.
Have fun.
-Chris-
-Sweetness-
-Turbocharged-
Thursday, March 10, 2005 2:16 PM
SunfighterGT wrote:There is a tach lead in the fuse box right above the battery there... you can't miss it. Read the fuse box cover and you'll see it.
Have fun.
-Chris-
Not on the 2000+'s
You could tap the pink wire on the IDI I think.
Thursday, March 10, 2005 2:39 PM
But im trying to find the wire on the pcm or is there one? No tach lead in the inside fuse or the engine fuse.
Thursday, March 10, 2005 2:45 PM
There isn't one. The PCM interpolates the RPM signal using the coil inputs.
Thursday, March 10, 2005 3:01 PM
I stand corrected - I haven't played enough with a 2k+ LD9... hmmm... GM really f*cked things up with that BCM eh?
-Chris-
-Sweetness-
-Turbocharged-
Thursday, March 10, 2005 3:41 PM
You can add a RPM signal wire on your car.
Pin 10 on connector 1. Black One.
I had to add one there for the RPM signal on my emanage.
Works great, thanks to The Pute 2!!
Later,
Jeff
2000 Turbocharged Silver Z24 5spd
Cardomain Site
Pictures and Information of Z24 Turbo Project
Thursday, March 10, 2005 3:58 PM
How would I go about taping it into the ecu. where can I get the pins for the ecu, how much, I need to get them by tomorrow, is this pinout certain I just dont want to put the pinf in the ecu and get a cel or burn up the safc or ecu. Let me know.
Thursday, March 10, 2005 4:30 PM
I just did this 2 days ago, so I know for sure it works on a 2k.
Get the pin from a dealer, its 20 ga wire.
I got the pin from a friend at a dealership, they have tons of them sitting around. Should be able to get it cheap if not free.
Hope that helps.
Later,
Jeff
Cardomain Site
Thursday, March 10, 2005 4:45 PM
on my 01z, i tapped the purple/white wire connecting to the IDI cover on the right side. i heard the pink, and also maybe the white could work...
Thursday, March 10, 2005 5:09 PM
I was told the ORANGE wire by afcavy. I used it when hooking up my SDS eic, and it worked perfectly fine.
LOL, so it looks like it could be alot of colors.
Thursday, March 10, 2005 5:15 PM
I know the pink on the IDI will give tach signal. My shift light is hooked to that. That will work for your SAFC.
Thursday, March 10, 2005 5:21 PM
I dont feel like running a wire to the ecu side of the car thats why I asked where at on the ecu you can put it. because thats where the safc wires are. Thanks Kane for the info thats what I was looking for. Thanks to all for the other posts.
Thursday, March 10, 2005 5:54 PM
Have fun.
-Chris-
is this on all years/engines ?
<a href="http://www.cardomain.com/id/fireside"><img src="http://www.influx.ca/avatars/toond.jpg"></a>
Thursday, March 10, 2005 5:59 PM
ok nevermind, I just went and checked, and yes I do have one.
now, new question:
how do you tap into it?
Thursday, March 10, 2005 6:02 PM
Listening....
___________________________
MAKING MY DREAMS A REALITY
Visit my cardomain site !!!
ELIOT. Now.....boosted.
Thursday, March 10, 2005 8:02 PM
anyone?
shifted?
chris?
Thursday, March 10, 2005 8:17 PM
Use a wire tap, or solder in a connection.
Thursday, March 10, 2005 8:31 PM
all I see is a square hole...... I dont know how I'd solder into it
Thursday, March 10, 2005 8:39 PM
Oh, you mean for the tach fuse thing...
Go to RadioShack, grab a fuse tap, and use that. Its basically a metal blade that sticks into the fuse holder, and the other end connects to a wire. Either that or you can tap the wire on the bottom of the fuse panel.
Friday, March 11, 2005 5:08 AM
When I put in my S-AFC a month ago Stevefire, I simply used a regular butt connector, the thin side... I used a set of cutters and chopped the connector down until it fit. Voila.
I also got power from my S-AFC at the ABS relay at the top right hand corner of the box.
Have fun!
-Chris-
-Sweetness-
-Turbocharged-
Saturday, May 14, 2005 5:00 PM
Hey guys, i myself have been looking for a full rpm signal without the pin 10 trick, iv now tried the purple/white on the idi cover, which gives random ass rpm signal at idle it bounces from 2000 to 4000 and @!#$ its crazy....and then i tried the pink.. and it gives nothing, i tried the orange and it gives Half rpm signal, i wonder about the white?....hm anywhere else on a 01 to get full rpm signal?...annnnnnd is the TPS on the throttle body? and i tapped the blue wire and i still get no throttle signal i dont kno wat 2 do
<a href="www.daptronics.com">www.daptronics.com Huge Discounts on Electronics</a>
Monday, May 16, 2005 6:50 AM
you prob need a tach adapter
Monday, May 16, 2005 9:09 AM
Derek Spencer wrote:Hey guys, i myself have been looking for a full rpm signal without the pin 10 trick, iv now tried the purple/white on the idi cover, which gives random ass rpm signal at idle it bounces from 2000 to 4000 and @!#$ its crazy....and then i tried the pink.. and it gives nothing, i tried the orange and it gives Half rpm signal, i wonder about the white?....hm anywhere else on a 01 to get full rpm signal?...annnnnnd is the TPS on the throttle body? and i tapped the blue wire and i still get no throttle signal i dont kno wat 2 do
i used the purple/white wire for my alarm. i did have the problem at first though that it would seem to give a quick "bouncing" up and down rpm. then i played with the settings for the number of pulses the alarm senses (between 1-16) and afterwards i found the right number of pulses for the alarm to count for the rpm's to be accurate. so yea you probably will need an adapter (in my case it was a setting on my alarm)
Monday, May 16, 2005 8:50 PM
YA that purple/white one makes them go crazyyyyyyy haha run from 2000 to 4 grand back and forth hahaha, i duno if i get half signal from one wire and half from another if i route the 2 together would i get full signal?......er would that fuk things up aswell?...my throttle is fine now tho, jus had 2 set it up..but rpm is hard 2 get 2 work..how much are the tach adapters, and where could i get one?...are there special kinds er?
