I want to upgrade to a larger turbo at some point, and the thought of how I would dial in my power delivery once all the bugs were worked out krept into my head. I know cams are a good way to shift power, but more specificly I wanted to discuss the use of changing your AR number. has any one played with 2 or more housings on the same turbo? how noticeable was it when changing ratio's.
Kick azz is my boost hero!!!
Not necessarily. There are housing options that use the same compressor wheel size for certain turbochargers. Like a .60 A/R housing and .70 A/R housing could fit the same wheel. But for the most part people swap to a bigger wheel and compressor housing to match. You'll have to search around and see if it's even possible to do a direct swap. It depends on what parts are available.
2001 Olds Alero (LD9)
650 whp / 543 ft-lb
@turboalero
Turbine housings are simple to swap as long as their the same trim shaft. I went from a .48 to a .63 and noticed it, will be using an .82 in the future.
Compressor housings are a bit different cause you have to change the wheel and in most cases the backing plate. I went from this..
to this..
Definitely louder spool lol. I had a 7psi spring in my wg and all the extra cfm of air pushed it to about 9-10psi.
