Stand alone turbo oil system. - Boost Forum
Thursday, April 30, 2009 3:53 PM
I have been trying to come up with some way of fitting a turbo under the hood of my car with the 3400 in it for some time now... The only thing I can come up with is doing a rear mounted setup... How well do you think a stand alone oiling system for the turbo would work? Id have a small resevoir (2 quarts or more) of oil and an electric oil pump mounted in the trunk of the car with the lines run to the turbo. I have been looking at pumps online and it seems like theres alot to choose from. Most put out around 2 gal a min@50psi.
3400 SWAP DONE. 187WHP 212TQ (14.2 @100MPH NA) 240WHP 310TQ (N2O)
Re: Stand alone turbo oil system.
Thursday, April 30, 2009 3:58 PM
Alot of the pumps I deal with at work have a thermal protector in it. It usually triggers it after a couple straight minutes of use. Not sure if any others are able to run for extended periods of time, but most likely there is one that can do it.
Thursday, April 30, 2009 4:52 PM
I think you are over thinking it.... You don't need a whole separate system. You can feed the turbo off of your engine, and will just need the pump for pushing it back to the pan. Here is a link to the manufacturer of the same pump STS uses for their pumps. Its the same pump thats on my Wife's car which has a remote mount turbo...
http://www.rbracing-rsr.com/oilsystems.htm
P&P Tuning
420.5whp / 359.8wtq
Thursday, April 30, 2009 5:42 PM
I don't see why you can't mount a turbo set-up in the engine bay. You can with a 3800 in a J, so why not a 3400.
Thursday, April 30, 2009 6:53 PM
The 3400 guys with Aleros mount them where the battery is/was.
2001 Olds Alero (LD9)
650 whp / 543 ft-lb
@turboalero
Thursday, April 30, 2009 8:53 PM
[ion wrote: C2]The 3400 guys with Aleros mount them where the battery is/was.
Thats a sick install... Nice and clean!
P&P Tuning
420.5whp / 359.8wtq
Friday, May 01, 2009 4:15 AM
If my turbo stuff does not sell and I end up using it I will be making a complete oiling system for it. Just the pump alone is going to be in the $350-500 range.
Wednesday, May 06, 2009 6:25 PM
The way my computer sits and the way my motor mount is on the rad support makes it almost (almost) impossible to fit it.
Sunday, May 17, 2009 4:46 PM
im sorry but a turbo does fit in a 3400 3rd gen much like the alero pic above.
11 psi
turbine wheel was hamburgered. Inducer on the turbine was the same size as the exducer!
farmerz24
Thursday, May 28, 2009 8:00 PM
Why wouldn't an $80 shurflo pump work? I'm using one for water injection successfully. You might need to put a cheap trans cooler on the intake side, but otherwise it should work great.
2002 Cavalier 2200 5spd
Friday, May 29, 2009 3:56 AM
A diaphram pump will fail due to the fluid and heat. I have read numerous articles about this exact problem with them. Even STS uses a gear type pump.
Friday, May 29, 2009 4:21 AM
Solid Snake wrote:Why wouldn't an $80 shurflo pump work? I'm using one for water injection successfully. You might need to put a cheap trans cooler on the intake side, but otherwise it should work great.
mitdr774 is correct. I went through 2 shurflo pumps before I came across the pump STS uses on their systems. ImPhat0260/Cavattack2000 has my old system installed on his wife's car. The RBRacing pump works perfect. Don't skimp on the most important part of a rear mount system that keeps it reliable.
I will NEVER change my sig. HTML 4 EVA!!
