What happened to Dragracemyz24 - Boost Forum
Sunday, May 04, 2008 1:08 AM
First night out on the streets after sitting for two years since buying my house. I finally completed the new turbo setup, running 12psi on 100 octane with gm reflash and hp tuners. Bigger turbo , externally recirculated wastegate, HO Manifold port matched and HO TB. I use to have a very restricted internal gate setup with a smaller turbo, 2" charge pipes, and it was fast then as many of you may remember from my old videos floating around the internet . OMFG is this thing a beast now . Amazingly fast .
Unfortunately I may have damaged my transmission last night ,but not from anything I changed in the HP Tuners software it was my dumb fault , lemme explain. Here is what I changed and what happened after running it pretty hard for a few hours at 12 psi. i downshifted at too high rpm and too high speed from 3rd then down into 2nd. My brakes were heat soaked and I had no choice. I also pulled up the e brake to help slow down. No fluid is leaking at all. After doing this it still shifts fine but is making a nasty ass whining sound and I hear some rattling that I can't pin point . I think the whining is the torque converter or pump and the rattling it sounds like a washer rattling on a bolt. This is my third transmission I am not exaggerating. The first one took a crap at 40k slipping terribly . I then purchased a 4t45e from a Saturn L series and swapped over the components from that to the 2.4 bell housing along with a Yank converter and a MTI trans cooler . This trans was to be the one that should have been more than enough. I got three 1/4 passes on it and about 150 miles and the trans and or converter started slipping horrifically . So I wasn't about to dive into it and instead found a 20k mile trans on eBay for $ 150.00 . I couldn't pass it up and just swapped that in there with a stock converter to play it safe since I wasn't sure if it was the trans or the yank converter that had taken a crap on me.
OK so my max pressure I left at 90 psi . I also did not mess with the force motor current as I did my research and read what Todd Miller had said about that not being the proper way of doing things. I also did not yet tweak the desired shift time table as it seemed to be keeping up with the shifts OK at 12 psi on my setup.
- Under Engine / Torque Management / Vs. Gear / Maxed out to 1500 ft lbs.
- Under Trans / Torque Management / Abuse Mode Disabled .
- Under Trans / Torque Management / Torque Reduction Normal
and Performance Tabs zeroed out .
- Under Trans / Shift Properties / Normal / Used a 1.15 Multiplier 6 clicks.
at the end of the chart in the 3 to 4 shift in the 320 ft lb column my
maximum number was 234
- Injector constant balanced out for the 440 cc's idles perfect
- Idle raised to 900 rpm
- Coolant fan on/off temp adjusted
- Speed limiter raised to 140 mph for track purposes
- secondary 02 sensor error codes dissabled
- Raised rev limit to 7000 rpm
I have done absolutely no VE Tuning , Fuel Tuning or anything timing related with HP Tuners other than the torque reduction settings . I am just using the reflash and the wideband sits perfectly in the 11.1 to 11.5 range under boost. Gotta love that two bar reflash program man. The car literally drives like it was intended to be boosted from the factory. Crisp amazing throttle response.
I love the auto trans with boost and I cannot explain how hard it pulls once the car spools. I do not lose to many cars on the street. But enough is enough and cannot explain to you how sad I am that I have broken another one. Fortunately I have a 2000 Z24 5 speed doner car that was my daily driver until totaled out on Jan 21 of 07. 5 Speed swap here I come. It has a Spec stage one clutch but other than that the car was stock . The 5th gear syncro was grinding on it . That is the only thing that worries me. I will now be doing a full 5 speed swap with LSD Insert , Getrag tranny , and a new spec higher stage clutch. I was going to give the doner car minus the motor to PhilioZ24 who did a Isuzu swap on his auto turbo Z and is also the one who helped me with all of the transmission swaps. He is now having nasty problems with the gay ass Isuzu. I have yet to tell him that I now need the parts for my car and I feel real bad about that. On with the pics. Not sorry for the long post since I have not posted too much here lately but am back now . Those of you who know me know how much I have been through with this car including the fire and multiple transmissions lol. I cannot quit here and might take that doner motor to be built also.
Windy City TurboZ
Re: What happened to Dragracemyz24
Sunday, May 04, 2008 1:13 AM
Old t3 super 60 Vs New t3 t04e
dolla bill shot yo lol jk
doner car and the WCT (Windy City TurboZ) with unfinished engine bay
doner car unsmashed and the WCT looking good .
Alot more to come .....
Windy City TurboZ
Sunday, May 04, 2008 1:21 AM
another manifold shot
another old shot but a goodie
Old setup
man heres a real old one 03
Windy City TurboZ
Sunday, May 04, 2008 1:29 AM
naturally aspirated
and when it was new . never posted . Nice bra huh lol
There are hundreds more at my mom and dads house on their computer I will post some more tommorow.
Windy City TurboZ
Sunday, May 04, 2008 1:37 AM
And here is me for those of you who don't know what I look like. Looking all grizzly adams . Unshaven
Cant say that this pic isn't turbo related hahaha this is an old one too.
Windy City TurboZ
Sunday, May 04, 2008 1:38 AM
All right I am officially done for the night 3:38 am lol see you tommorow jbo
Windy City TurboZ
Sunday, May 04, 2008 3:43 AM
LOL it's like you all disappeared for mad long and now just was like hey guys, whats up?!
LE61T PTE6262 Powered
Sunday, May 04, 2008 6:07 AM
Man I never even though about using some sort of dumptube to relocate my wg...wow I feel dumb lol. That could have saved me alot of issues before when I was gona turbo.
More engine bay pics!!!
Sunday, May 04, 2008 6:11 AM
good luck and keep us updated.
Sunday, May 04, 2008 7:39 AM
seriously...nobody really cares anymore...you're kind what they say is a "has been"....
Good to see ya back bud keep it up
Sunday, May 04, 2008 11:37 AM
finally got that bitch running huh....ill be in decatur all summer but we should deff. chill sometime soon
Sunday, May 04, 2008 12:12 PM
Nice man, lets see some vids dammit hehe
Sunday, May 04, 2008 4:17 PM
More engine bay pics coming real soon guys. Yeah QBE I use to talk to you all the time back in the day. Mclovin you bet ya man. I got your number. Thanks Jake and everyone else. I have always been kinda lingering on here but had no new info to post but now I do finally. I will keep you guys updated on the car's ongoing progress and will definitely have some videos too.
Windy City TurboZ
Sunday, May 04, 2008 4:29 PM
i remember when it started on fire. got any pictures of that?
Sunday, May 04, 2008 6:48 PM
haha yea man thats how we do. real og's stand up!
Blew it up, build numbers coming soon
Monday, May 05, 2008 5:45 PM
Dont feel bad. I can make do with what i have ...not a big deal ..just let me know what your going to do so we can set up a time to swap it out AGAIN!!!!!!!!!
Monday, May 05, 2008 8:08 PM
Phil I love you man. You have helped me so much and you have no idea how much I appreciate it.
Here are some engine fire pictures for you guys to reminisce over lol ... Blown power steering line sprayed all over the manifold on the old setup. Burned for one minute. My brother saved the car by ripping the fire extinguisher off the 7 Eleven wall. Thankyou Cammron . I ran one way and he ran the other hahahaha. I reached back in to grab my wallet and phone when he blasted it with dry chemical. I thought the car exploded when he did that. How he reacted so quickly was amazing. Smart kid man . I at times wish he let it burn though lol ..... Man memories , some good some bad but its been a long road...
Windy City TurboZ
Tuesday, May 06, 2008 3:49 AM
I remember when the car caught fire.....
Tuesday, May 06, 2008 9:03 AM
Lookin good.. Glad to see you back!
P&P Tuning
420.5whp / 359.8wtq
Tuesday, May 06, 2008 9:13 AM
what kind of turbo manifold is that??
Edited 1 time(s). Last edited Tuesday, May 06, 2008 9:13 AM
Riddle me this... riddle me that...
