help with turbo prob - Boost Forum
Friday, March 02, 2007 5:20 PM
Hi
My question is how do you know when the turbo is going out?
thanks
IG
Re: help with turbo prob
Friday, March 02, 2007 5:33 PM
smoking, leaky seals, shaft rubbing the housing are probably the best hints.
Blew it up, build numbers coming soon
Saturday, March 03, 2007 12:56 AM
if you are talking about "worn out" you would look for:
-excess oil in the intake tube (possibly with brass shavings)
-abnormal smoking from the exhuast pipe
-increased turbo lag
-decreased boost
-fin damage from rubbing on housing
those are in order.. catch it early... cause if you have the last one.. you have all the others.
Saturday, March 03, 2007 2:33 AM
thanks for the info.....but if the fin's are rubbing on the housing, could you only hear it while your driving or could you also hear it when your in park/neutral? Im asking because i just started to hear like a scraping sound when you start to excellerate from a dead stop and then you dont hear it anymore when your in mid to high speed. When i put the car in park you dont hear it or in neutral.
