Refrigerant Pressure - Third Generation Forum
Sunday, August 12, 2007 8:30 PM
does anyone know the normal pressure range for the low side 134-a refrigerant on a 98 cavalier?
Re: Refrigerant Pressure
Monday, August 13, 2007 8:48 AM
Just get a guage from autozone when you buy a bottle of R134-a it's like $25 total for it all... and the guage tells you when it's empty, full, caution, danger I personally like to keep mine in the full/caution area... also read the directions... it says to move the bottle up to the 12 o'clock position then back to the 3 o'clock position evry two to three seconds... this does wonders for the A/C! Also I'd recommend getting the refrigerant that has the "STOP LEAK" also... just in case your car is like mine and has alot of miles. PM me if you need to know anything else...
Monday, August 13, 2007 2:57 PM
low side should be around 45psi, and the high side should be about ambient temp times 2.5, so if its 80 should be 200-220psi
Thursday, August 16, 2007 5:40 AM
Rob S wrote:low side should be around 45psi, and the high side should be about ambient temp times 2.5, so if its 80 should be 200-220psi
that is of course, with it running and a/c on.
Friday, August 17, 2007 12:36 AM
and if you didnt know you fill it to 1.5 lbs
