What milage did your thermostat crap out? - Third Generation Forum
Wednesday, December 06, 2006 9:15 AM
around what milage did your cars thermostat go bad. mine just went at 80,xxx lol just seeing about everyone else.
Re: What milage did your thermostat crap out?
Wednesday, December 06, 2006 10:23 AM
121,750 or so and still working great.
Wednesday, December 06, 2006 11:19 AM
im at 126k and still going
Wednesday, December 06, 2006 4:11 PM
well i thought mine was bad @ 70 tho, replaced it... day later replaced water pump.... be aware it is deff. a chevy thing, they dont like the new pressure, replace ure thermostat and prepare for your water pump to piss coolant . car still likes to get real warm at stand still so prolly a head gasket...just keep on plannin the 5k clutch drops and reverse to first burnouts
w0rd on top of w0rrd
Thursday, December 07, 2006 8:43 AM
yea who knows with this car. I wanna get rid of it more and more everyday.
Monday, December 11, 2006 1:12 PM
how do you know when the thermostat is on its way out any easy signs of it? thanks i have 236kms on mine and asfar as i know it works good
Tuesday, December 12, 2006 10:43 AM
A sign of a bad thermostat is an engine that overheats at idle but doesn't at speed or when revved; a bad thermostat can sometimes cause overheating on the highway depending on the car...I know ours does because when my thermostat crapped at 210k miles it overheated an hour from home...I want to drive this car off a cliff sometimes but it's gotten me about 220k of travelling so far so i guess it's not THAT bad...too bad the engine is falling apart as fast as the rest of the car. by the time the engine is shot(should be in the next 20k or so) the rest of the car will be worthless too...last time i EVER buy a cavalier. Time to buy myself another 1980's RWD 5 speed inline 6 for a daily driver.
'96 Cavalier Good ol' Pushrod 2.2
-24X,000 miles on factory build
-Some oil loss between changes, me thinks it be rings.
Tuesday, December 12, 2006 9:30 PM
my car wont get up to temp hotest it gets up to is 150. Seems like the thermostat is stuck open.
Tuesday, December 12, 2006 10:18 PM
someone could have put in a 160 degree thermo and your cluster just reads 150, Does it heat up to 150 quickly or very slowly. if it has a thermo it'll heat up fast and level off. I put 195 deg thermos in my cars for better efficiency.
Wednesday, December 13, 2006 4:17 PM
It just started. It will go to 195 then drop down to 150, also it's very very slow to warm up to when it finally decides to, also it drops very quickly on wide open throttle.
Thursday, December 14, 2006 6:30 AM
Sounds like they didn't put a thermostat in it at all. I've known lazy people that do that. They take the old one out and don't bother putting in a new one(like it takes so much time and effort to do once you've removed the old one) I think it's more of a cheapass thing lol. It causes fluctuations like that. The WOT drop is because there is nothing to hold the water back so when you floor it it cools like crazy.
Thursday, December 14, 2006 10:18 PM
why would it do it all of a sudden I've had the car 2 years now and now out of the blue there it would do that. It's go a T-stat in it. I think it's just sticking partially open all the time had it before. I think when I put in the new 180* T-stat I'm gonna flush the cooling system and put the green antifreeze back in it. I've seen alot of problems with corrosion from the dexcool.
Friday, December 15, 2006 7:58 AM
Well in winter weather, mine doesn't ever heat up... I'm lucky to see 150*, and if I want to turn the heat on...forget it. Its a 2002 2.2OHV, I just assumed it was a cold-blooded beast. It heats up to 195 in the summer, and only goes over if it idles excessively.
Anyone else have this experience
Friday, December 15, 2006 8:27 AM
check the coolant mixture, is the fan constantly running keeping the motor cool. replace your thermostat. if your fan is staying on make sure you dont have a check engine light on or make sure a temp or fan switch isn't going bad.
Friday, December 15, 2006 10:17 AM
Yea if something is wrong...it has been wrong since I got the car about 70k miles ago...
