Ok I know this has been discussed but I have discovered some new info for my problem. It's that my ABS, Service and Trac Off lights are always on. Obviously this is due to a faulty speed sensor. I tried cleaning them but no help. Then today I searched on ALLDATA and found a TSB for this problem. It says that it can be cause by a faulty connection on the left front sensor and the harness may need replaced. Has anyone else heard of or tried this? If so did this solve your problem?
We Ride Together, We Die Together...... J-Bodies For Life!
SPONSORED BY: Showstopper Tuning, JM Graphics
2003 Cavalier LS Sport "SHOCKWAVE"
i always thought my left front was the problem. my abs light is on too. I do know the insulation is worn off and the wiring a lil frayed, but i taped over it and hoped for the best. i just put up with no abs for now
well I put it on a computer and it says both fronts are screwed up anyone know where I can get a new set?
Patrick Myers wrote:well I put it on a computer and it says both fronts are screwed up anyone know where I can get a new set?
From an auto parts store maybe?
1983 Camaro Z28
I checked and they are 80 bucks a piece! I wanted to see if I could find em a lil cheaper
Hey i also have that problem I also have abs trac pff service lights on. I also think it is one of the front wheel sensor or maybe the ECBM. HAve you got it fix?
i replaced mine lastnight and everything is fine now, was a cracked wheel sensor and it was making the plug loose.
Patrick Myers wrote:I checked and they are 80 bucks a piece! I wanted to see if I could find em a lil cheaper
One sensor and one connector cost me $213CAD (about $200USD) from the dealership, back in the summer (only place in town that had them). Consider that price a steal.
2002 Sunfire -->
- Ractive steering wheel
- ASA 17" EM9 + Nexen N5000 215/45/17 (steelies for winter)
- D-Spec Lowering kit @ 1.4" (issues currently
- Rockford P250.1 + MTX MZS1004 + Panasonic CQ-C8313U head unit
- Barely legal tint.
I have the same issue, but the wire snapped just in between the tires. Damn snow!
firemachine69 wrote:Patrick Myers wrote:I checked and they are 80 bucks a piece! I wanted to see if I could find em a lil cheaper
+1. dealership here wants $170 just for one sensor. if you can get them for $80, jump on that ish.
