I have a '96 Cav., 2.2L. I've noticed a lot of body roll when I go around corners. I know I probably need new struts, but will a strut bar help with this? I see them all over on Ebay.
I just have factory struts, nothing fancy.
Yes asuming you have it installed correctly.
![](http://i37.photobucket.com/albums/e69/wjz24/notforsalesig.jpg)
Stiffening the chassis will almost definitely make a bit of difference, but the question is whether it will be able to notice while riding on otherwise stock suspension. I suspect not, but for the price it's worth a shot. Even on stock struts and springs, a better supporting upgrade for managing body roll would be front and rear anti-sway bars.
![](http://www.geekjosh.com/avatars/avatar2.gif)
Shop Manuals, Brochures:
www.kenmcgeeautobooks.com
No, a strut bar will only stiffen up your structure, it will make your steering more compliant. To reduce body roll, you will need stabilizer/sway bars. New shocks will help too.
>>>For Sale? Clicky!<<<
![](http://img196.imageshack.us/img196/8941/gmgoodwrenchnew2logo.jpg)
Mr.Goodwrench-G.T. wrote:No, a strut bar will only stiffen up your structure, it will make your steering more compliant. To reduce body roll, you will need stabilizer/sway bars. New shocks will help too.
^^ what he said
you will notice a difference with the brace , but the car will still wave at people going around corners
being that you said you have a 96 2.2 , there is a good percentage of them that did not come with a sway bar in the front from the factory , so chances are you will need a bar up front also
[quote=97trd(???™)]
X2
OK, I guess I'll just skip it & spend the money on new struts then. Thanks.
Ok. I have a 99 Sunfire 2.2L Coupe. I'm a bit foggy on this. But a rear strut bar from a Cav will work on a Sunfire right? Since they're the same build. Thanks
"Winning in a p@$s fight in a forum is like winning a race in the special olympics. Cuz in the
end. Your still a retard."
Stephen Young wrote:Ok. I have a 99 Sunfire 2.2L Coupe. I'm a bit foggy on this. But a rear strut bar from a Cav will work on a Sunfire right? Since they're the same build. Thanks
Yes, unless the receiving car is a convertible.
Edited 1 time(s). Last edited Wednesday, July 11, 2007 12:46 AM
