Im going to be adding a body kit and doing some body work to the car. Im just wondering would it be ok if i added a 17 or 18 inch wheel with my stock suspension, would it give me any problems or break, blow??? anything
you will be fine
it will work fine but u will get that 4X4 look
But wouldnt adding larger wheels close the gap?
not if you use the right profile tire
it will make the gap look smaller
but in reality it wont really do much
Get the right size tire! Check out the Tire FAQ in the Wheels forum.
The gap will appear smaller with all that rim in there, but it doesn't actually change much. It will improve handling. You wont wear anything out faster than normal.
C.T.S wrote:Get the right size tire! Check out the Tire FAQ in the Wheels forum.
How will he improve handling if he is only doing wheel and tire? Sure the tire can provide more grip and sidewall stability, but is it that drastic? The larger wheel might also add weight, thus adding more rotating mass (although this is probably more delt with for braking). The nuts and bolts of the suspension is still stock. Until he gets down and dirty, I don't see the handling changing much, if at all.
Depending on the tires, yes.
Tires don't make up for good springs and struts, but there is a noticable improvement.
C.T.S wrote:Depending on the tires, yes.
Yes, noticable, but is it that drastic to now take turns 10 MPH faster? I know where this is going...I just don't see it making that MUCH of a difference without proper suspension set ups. Otherwise, you will not get the fully potential of the tire.
youd be suprised what good tires can do
Jason wrote: Yes, noticable, but is it that drastic to now take turns 10 MPH faster? I know where this is going...I just don't see it making that MUCH of a difference without proper suspension set ups. Otherwise, you will not get the fully potential of the tire.
A set of z-rated tires will let you corner faster than your your stock p-rating. the compounds are different. Z rated, for example have a real soft compound which allows for maximum grip for cornering. This soft compound shortens tire life though. the p-rated has a more durable compound made for comfort and a longer life.
Z rated tires now have been split into a w and y catorgory but both are made for speeds of 149+ mph.
I don't know...I just don't see the car handling THAT much better. But, I'll take your words for it, you guys know best!
Ok so the final word is, that if i do change my rims (add an 18 over stock) and then put rubber on it, with stock suspensions, nothing would happen to my car noticeable, nothing would break, and the gap that is now there will also shrink. I guess thats how i picture it, since adding larger wheels should cut the gap down.... RIGHT?
NO. The gap will be the same size. It will look smaller from the optical illusion.
C.T.S wrote:NO. The gap will be the same size. It will look smaller from the optical illusion.
True.
This is because you will also have less of a sidewall. Make sure you get the proper size tire or your speedo will be way off. But everything will be the same dimensionally.
Cool, i got this straightened out, thx for the input
