91 cav 2.2, no spark 1&4..HELP! - Second Generation Forum
Saturday, June 13, 2009 4:22 PM
91 cav 2.2 125K miles all stock, lost spark on 1& 4, put in new coil and worked for 2 days, then went bad again. Its such a B&*%# to get at I replaced ignition mod and both coils, plugs and wires replaced 10 months ago...still no spark at 1&4 any help appreciated, I'm stuck
Re: 91 cav 2.2, no spark 1&4..HELP!
Sunday, June 14, 2009 2:19 PM
where did you get the coil? sounds like a bad coil or ignition module
Monday, June 15, 2009 4:21 AM
Got ICM at autozone, re-tested it and tests OK, coils came from local parts house, tested them and OK too . HMMMMMMM
Monday, June 15, 2009 12:10 PM
Check the ICM plug, a wire may have pulled out or broken and isnt making contact. I had that happen with my alternator plug once and the alternator was good but wasnt charging for some reason. I changed the plug and it worked flawlessly.
Monday, June 15, 2009 2:13 PM
Problem solved ICM was cutting out when hot, tested ok when cool, swapped it out for another one(the repair shop did) and now all ok...but I am $200 poorer, but wiser(I think)
Tuesday, July 07, 2009 10:27 AM
this may be a dumb question, but what is ICM? My '93 that I race on dirt tracks has been cutting out, only when it gets hot (and only coming out of corners, curiously enough) and I have been trying to hunt down the gremlin that is causing it.
Tuesday, July 07, 2009 10:44 AM
Ignition Control Module. Coil packs bolt on to it. ICM, coils, and CPS can all start acting flaky when hot making cold testing a shot in the dark.
