I want to upgrade the ignition in my car and was wondering, can I just replace the coil pack with remote mounted coils and run plug wires without having to buy an MSD box? I figured I could buy higher voltage coil packs and help a lil.
We Ride Together, We Die Together...... J-Bodies For Life!
SPONSORED BY: Showstopper Tuning, JM Graphics
2003 Cavalier LS Sport "SHOCKWAVE"
coil packs transfer the energy.
the msd is the amplifier....
kinda hard to make a bigger spark without an amp, right?
well I didn't know if swapping in a higher voltage coil would help at all. just curious see if i could save the 400 bucks
Actually, the MSD coil packs (along with most after market ones) are lower voltage, the stock is 45k and after market is 40k. The new packs simply have a better response.
_________________________
you guys realize that the voltage you are talking about is the max voltage they can handle right?
GM 2-Tower Coil Pack used on vehicles from the mid 1980s to late 1990s
PN 8224
BLASTER REPLACEMENT SPECIFICATIONS
Primary Resistance: 0.35 ohms
Secondary Resistance: 7.8K ohms
Maximum Voltage:
40,000 volts
Inductance: 4.2 mH
Turns Ratio: 80:1
