Red line water wetter and GM red antifreeze? - Performance Forum
Sunday, November 04, 2007 4:49 PM
can i use Red line water wetter with the gm red antifreeze?
thanks,james
Re: Red line water wetter and GM red antifreeze?
Sunday, November 04, 2007 4:57 PM
wtf is gm red antifreeze? dex cool is orange, but it doesnt like to mix with ANYTHING.
Sunday, November 04, 2007 5:12 PM
yeah thats it lol sorry i been under my car butting a heat exchanger in all day
Sunday, November 04, 2007 6:14 PM
I'm using water wetter with Dexcol, works fine.
Sunday, November 04, 2007 8:26 PM
water wetter works with all coolants...i run it in my j and it makes a noticable difference
Sunday, November 04, 2007 10:17 PM
gareth vasile wrote:water wetter works with all coolants...i run it in my j and it makes a noticable difference
x2
Thursday, November 08, 2007 11:32 AM
x2
X3
Thursday, November 08, 2007 1:41 PM
wtf is 'water wetter' ???
Thursday, November 08, 2007 1:54 PM
Brad it is a product from Red Line Oil.
WaterWetter®
WaterWetter® is a unique wetting agent for cooling systems which reduces coolant temperatures by as much as 30ºF. This liquid product can be used to provide rust and corrosion protection in plain water for racing engines, which provides much better heat transfer properties than glycol-based antifreeze. Or it can be added to new or used antifreeze to improve the heat transfer of ethylene and propylene glycol systems. Designed for modern aluminum, cast iron, copper, brass and bronze systems. Compatible with all antifreezes, including the latest long-life variations.
Monday, November 12, 2007 12:11 PM
Ive used the product too, Works very well. In my cavalier as well is in my other Gm cars.
Tuesday, November 13, 2007 4:12 AM
z yaaaa wrote:wtf is 'water wetter' ???
Water additive that reduces surface tension. Used in computer water cooling a lot as well for lower temps.
Tuesday, November 13, 2007 5:30 AM
I run a mix of water wetter and distilled water in mine, granted I only drive the car in the summer months so I don't have to worry about it freezing. My coolant temp never passes 180 degrees even sitting in rush hour traffic in the middle of the summer.
Quoth the Raven 'Nevermore
raven@accesswave.ca
Raven Autosports
55 McQuade Lake Cres,
Halifax, Nova Scotia, Canada
(902) 850-3330
10.82@132
Tuesday, November 13, 2007 5:59 PM
can water wetter be added during winter aswell?
Tuesday, November 13, 2007 8:02 PM
hmmm where do you buy this stuff and does it just add into the holding tank?
http://www.cardomain.com/ride/2623318
Tuesday, November 13, 2007 8:12 PM
jesterz413 wrote:hmmm where do you buy this stuff and does it just add into the holding tank?
is it worth a buy? If it keeps the engine a bit cooler, like it sounds, wouldn't it be better for the car in the long run?
Tuesday, November 13, 2007 8:49 PM
Uh, guys... Hate to be the "wet towel in the face" here but true GM Dexcool already has Water Wetter as part of it's makeup. Just something I read about 10 years ago when I had my '85 2.5L S-10 and put it in. Big difference in heat transfer 'cause of it, made the heater work alot better. Just sayin'.
Go beyond the "bolt-on".
Wednesday, November 14, 2007 12:55 PM
my cav always gets up to like 230 or so in summer. couldnt hurt to try it
