port and polish? - Performance Forum
port and polish?
Saturday, September 22, 2007 2:12 PM
hey guys all i need are some quick answers i am going to be porting and polishing my head and doing the secret cam swap . would it be worth doing the cometic head gasket now because i plan on supercharging over winter. and are head studs worth getting? and the turbo tech racing valves sorry so many questions i will be looking this up right now but just seeing if i could get some help since i pan on buying this stuff this week
http://www.cardomain.com/ride/2623318
Re: port and polish?
Saturday, September 22, 2007 2:49 PM
and would it be worth my time to do the pistons and rods i am not trying to go to crazy into it think port polish ,cams ,headers ,exhaust intake and then a supercharger would be fine i mean thats pretty good amount of stuff..
Saturday, September 22, 2007 3:42 PM
You won't have to worry about pistons or other internals unless you're planning on pushing past 8psi. You will however need a new clutch (I'd recommend a stage 2 if you're street driving it). Any gasket you take off to put the supercharger on will have to be replaced, so leave it until the supercharger.
_________________________
Saturday, September 22, 2007 3:58 PM
i already have that putting it in tom actually with a light weight flywheel. and i mean i am going to get the cometic head gasket . for [porting the head and with the cams think it would work good?
Friday, September 28, 2007 7:51 AM
You should be fine, I have one note though, you shouldn't turbo with the lightweight flywheel (if you were ever to consider it), I've heard of the torque ripping them apart.
Friday, September 28, 2007 11:59 AM
Friday, September 28, 2007 12:09 PM
He said turbo, been running a Fidenza 8 lb F/W for 15000 mi. with my SC. No problem.
Labrat
Friday, September 28, 2007 12:58 PM
for porting with the head.. focus on the exhaust.. most restriction=more power to free up...
opening the exhaust side to match the header gasket is best.. but thats a lot of metal.... so i would just deburr and sand the ports smooth... its a good power freeier
"Z24 Dustbunny"
