What can i shave off of the 2.3HO mani? Pic* - Performance Forum
Saturday, August 12, 2006 7:41 PM
I want to shave up and smooth out my 2.3ho manifold i just got, but can anyone let me know what brackets etc i can cut off and smooth down on the manifold so i can powder coat it and give it a cleaner look.
If possible. you can copy picture and circle in mspaint what i can get rid of. im not to sure as motor is at machine shop to compare what i need to keep
thanks
-Choko
Re: What can i shave off of the 2.3HO mani? Pic*
Saturday, August 12, 2006 8:05 PM
you sure thats an HO?
Saturday, August 12, 2006 8:33 PM
That looks like my LO....
Make sure thats a true HO before you do all that work.
It took me 16+ hours to completely smooth my LO intake manifold....and I took it back off my car only after two weeks. Car with out a drought slowed down. 6-8 tenths at the track...
~~~shakes head~~~
Saturday, August 12, 2006 8:37 PM
how can i tell?
Saturday, August 12, 2006 11:50 PM
Ok. this has to be a HO manifold. part # on it is: 22538691
Sunday, August 13, 2006 5:46 AM
Shave off all the square nubs.
From left to right.....
1st runner shave the circle nub.
2nd runne keep the circle.
3rd shave
4th (closet to the tb mounting point)... you can keep it if you wanna use the 2.3L mounting bracket and use CC.
But tilt the thing down so we can see if its HO or LO, we need to see the whole plenum from the front.
-M
Sunday, August 13, 2006 5:53 AM
You can shave off this much. It is a bad angle but you get the idea
Jason
99 Z24
Racers Edge
Johnny Mack Turbo Systems
Engineered Performance
Sunday, August 13, 2006 7:37 AM
WHat flange is that on t here?
-M
Sunday, August 13, 2006 7:57 AM
listening....takes his LO manifold and throws it in the garbage...
serial 24572385
well.. looks like its back to the boneyard..
Sunday, August 13, 2006 7:59 AM
Dont throw it away.
Trade it at the yard.
Maybe they'll let you swap it or at least get the core charge back.
-M
Sunday, August 13, 2006 8:28 AM
There are a couple of other HO part numbers: 22538691, 24570288, 24571319. I just finished installing part #24571319 in my Cavy yesterday. Make sure before you trash it. As fo any gains, it's fairly minimal. Say bye bye to low end power band. However, it looks great and sounds better. Overall it's a much more even power band but it it doesn't knock your socks off and won't without further modding. Good luck deciding if you still want to do it.
Sunday, August 13, 2006 2:01 PM
you can shave off all of the nubs if youd like but as stated above and what i did is i left the round one closest to the throttle body to mount the tb cable bracket
Sunday, August 13, 2006 3:26 PM
OK, here's my cast manifold educational picture. Top left manfiold is an HO modded to fit a 2.4, top right is a stock HO manifold, bottom right is a log style LO manifold, bottom left is another style of LO manifold(can't remember if it's old or new, doesn't really matter in this case). Note the size of the plenum on the HO manifold as opposed to the LO manifold. This is the easiest and quickest way to check to see if it's an HO. The LO tapers off quite drastically away from the throttle body, while the HO only has a slight taper, with a larger plenum.
As far as what you need to keep to make the manifold functional: Not a damn thing. Shave off every blemish that you feel like. In the end you need to bolt a throttle body to the manifold, and bolt the manifold to the car. You will use the two fittings between the runners for vac sources, and all other holes can be capped with CNC plugs.
Here's what I did with mine:
Sask GM Performance (formerly SaskJbody) president
Sunday, August 13, 2006 3:51 PM
thanks all for the in depth info and help. ill post pics when i finish it
Monday, August 14, 2006 9:42 AM
LO or HO, I don' think anyone has dynoed the difference, for a turbo application or any boost app. I think the LO would work better, correct me if you think I am wrong..
Monday, August 14, 2006 9:59 AM
id leave the 1 of the 2 stands for the map sensor , since the map looks funny with nothing holding it up
Monday, August 14, 2006 11:21 PM
how did u get your valve cover to say 2.4l and high output lol
Monday, August 14, 2006 11:27 PM
^^^ custom deal.
But yeah its pretty neat.
-M
Tuesday, August 15, 2006 12:02 AM
Matt, your fuel lines aren't polished
