Tough choices - Performance Forum
Tough choices
Tuesday, May 02, 2006 8:17 PM
Hello there guys, I am undecided as to which part of the engine or bolt on I should replace next. I have already put in a cold air intake and new headers which work wonderfully but I am unsure what I should do next.. Money is not much of a problem right now because I just got back from Iraq so I have some money saved up. I want to prep the engine and all the other parts so that on a later date I plan to bolt on a Hahn racecraft Stage 2 turbo. but I am having a tough choice. I am new to the j-body scene but I must say I like it but I am having a tough choice
Re: Tough choices
Tuesday, May 02, 2006 10:26 PM
We have on header!!
Go with a larger exhaust. Have it custom bent. Get a Magnaflow cat and a muffler of your choice. Another good idea would be to grab the largest size resonator you can find.
You could do internals if you plan on boosting, but they are usually pretty good with the boost stock.
I'm not much up on a lot of internal stuff, so I can't be of much more help.
Re: Tough choices
Wednesday, May 03, 2006 5:03 AM
start preparing for the turbo. like dont buy parts you dont need like a header.
Re: Tough choices
Wednesday, May 03, 2006 8:13 AM
I know but I had the headers b4 I decided I was going with the turbo
Re: Tough choices
Wednesday, May 03, 2006 8:23 AM
We only have ONE header!!!!!
Re: Tough choices
Wednesday, May 03, 2006 1:40 PM
ok stupid mistake jason lol
if your soon to be going turbo then when you get an exhaust just get it at 2.5 inchs now or even 3 if you feel friskey but i would recommend 2.5.
Also seing that w/ the turbo kit and it coming w/ alot the only other things i would do performance wise would either be a B&M short shifter, motor mounts, trans mounts, and any suspension you want.
Like stated before do worry about a whole lot of bolt on stuff w/ the HAHN kit cuz you may be buying useless parts
Re: Tough choices
Wednesday, May 03, 2006 1:42 PM
actually i apologize for that post w/o looking in your profile first....just do any of the things you have listed under the future and your good to go.
Re: Tough choices
Wednesday, May 03, 2006 1:51 PM
get a wideband, and boost gauge
AEM and Autometer
Re: Tough choices
Wednesday, May 03, 2006 11:49 PM
You need to finish off your exhaust if you plan on running turbo. You can basically do everything from the downpipe to the tip because the turbo manifold you'll need in the future will work off any downpipe that's in place. A turbo (obviously) can't spool up with 1&7/8" tubing for exhaust (your stock stuff)
