hey gys and gals. i'm new to the site and have had my cavy for about 3 years now spendin all my time and money doin it up lol.. i was just wonderin if i have to rewire the car to run a 2.4 instead of a 2.2 or can i get away with the whole harness and just changed the computer
thanx .. Jay..
You would basically need the ECU, Engine, Transmission, Ignition System, Fuel system, all the hoses & wires...basically, everything out the engine bay. It's best to buy a donor car to do the swap.
thanx guys.. i'll think i'll do that to the next one lol i'll just finish the motor i got now lol
You have a 99 2.2? Swap in a 99 2.4L with transmission... keep the same type of trans... and it's a bolt-in, plug and play swap. No need to change anything past the wiring plug near the brake booster.
LENKO IS GOD!!!
"Peter Griffin: Brian, there's a message in my Alpha Bits. It says "OOOOOO".
Brian Griffin: Peter, those are Cheerios. "
i have a 95 sunfire. so what year 2.4 could i use because in 95 they came with the 2.3
patrick conrad wrote:i have a 95 sunfire. so what year 2.4 could i use because in 95 they came with the 2.3
If you had a 2.3 in your vehicle and wanted to go with a 2.4 now, you'd have to switch computers being that the 2.3s were OBDI computers and all 2.4s are OBDII computers.
then you need to stop looking at twincams and start looking at something that says High Output on the top of it or better yet w41
whoa hold up... lenko if mines a 99 your saying all ill need is the engine from a 98-99? so all id need to pick up is the 2.4 and the getrag tranny from a 99 of course. and everything else is plug and play?
JBO'S Mr. 64.....
Mr.64 (Shaune Drake) wrote:whoa hold up... lenko if mines a 99 your saying all ill need is the engine from a 98-99? so all id need to pick up is the 2.4 and the getrag tranny from a 99 of course. and everything else is plug and play?
Yes and No. You'll also need the 2.4 engine wiring harness that is a manual since you already have a manual.
2012 numbers - 4SPD
AUTOMATIC!!
anyone got a 98-99 2.4 engine there willing to part with?
JBO'S Mr. 64.....
Remember the 98's had the EGR valve.. The mid to late 99's don't have the egr.. You'll have to take that into consideration when searching for a wiring harness as well.. There are a couple engines in the classifieds right now.
The Getrags were on the 2000+ manual j-bodies, the Isuzus are on the 95-99s.
oh snap so i wouldnt have to change transmissions would i.
JBO'S Mr. 64.....
all the engines in the classifieds are far away....
JBO'S Mr. 64.....
Mr.64 (Shaune Drake) wrote:oh snap so i wouldnt have to change transmissions would i.
The transmission is the same but the bellhousing is different.
Since you have a 99 2.2L 5 speed... you could take a 99 2.4L 5 speed and bolt it in, either with the engine harness or modify the 2.2L one to work (it's pretty similar...). Have GM reflash the PCM from 2.2L to 2.4L, and you're good to go. Probably the easiest swap to do, since you're already a 5 speed you don't have to piss around with mounts.
You'll want the 99-02 engine, but the 99 (Isuzu) 5 speed transmission in order to just "bolt in". If you want the Getrag trans, that's the 00-02... and you'll have to modify the front trans mount, and replace the rear mount, and change the clutch cylinder, line to the slave, the shifter assembly, etc.
I'd suggest, simply for ease of install, the 99-02 engine with a 99 (Isuzu) trans. Easiest to do.
ive got the isuzu tranny already though correct. so wont my tranny bolt right up to it?
JBO'S Mr. 64.....
