what mods to do next, recommendations - Performance Forum
Friday, July 15, 2005 7:20 PM
hey, my goal for my car is to have it NA and break into the easy 14's for now. So far i have a header, 2.25" catback, intake, bored 59mm tb, aem alt pulley (in the mail) and car customs engine mounts (in the mail). What do you guys recommend i do next, i have a good amount of cash at the moment because i work for the county so thats not a problem really and i was thinking of getting a 2.4 head from the local junk yard and getting it ported and polished by my car clubs machine shop, getting the b&m shiftplus kit and getting the apexi afc because when i dynoed my car the guy showed me where the air/fuel curves should be and i was running 12 and the dyno showed it should be at 13 (running little rich) so getting the afc would slightly help me im guessing because the lags would be gone hopefully. thanks guys
Re: what mods to do next, recommendations
Friday, July 15, 2005 9:46 PM
Easy...do head-work. Contact Jbody Performance about upgrading your cams and seeing what kind of package they have for a ported & polished head for the 2.4 motor.
Seeing that your auto, i'd look into a Torque Converter & Auto Trans Interceptor. For more info on the converter, check out the transmission forum.
Saturday, July 16, 2005 12:21 AM
try the HO intake manifold, secret cam swap, crank pulley, then head work.
View my MySpace
Saturday, July 16, 2005 2:23 AM
Head work and cams are where it's at bro. You'll hit mid 14s with your current setup, a good head job, and the JBP stage 2 cams.
Saturday, July 16, 2005 2:30 AM
Spotabee Racing wrote:Head work and cams are where it's at bro. You'll hit mid 14s with your current setup, a good head job, and the JBP stage 2 cams.
Also big thing, check your fuel...you might run rich or lean depending on how your computer reacts to your modifications.
Saturday, July 16, 2005 2:36 AM
JBP's cams don't seem to cause PCM's to throw any fits. But valvetrain + headwork and you never know. It's always a good idea to reset the PCM by disconnecting your battery before doing something like this.
Saturday, July 16, 2005 2:40 AM
No silly...not as far as throwing codes. I meant how the computer reacts as far dumping too much fuel or not enough.
After you do the Valvetrain work, get a dyno done and they will check your A/F ratio and tell you if you need any upgrades or not. Myself, I did exactly that on my ECOTEC and I was running VERY rich.
Saturday, July 16, 2005 7:16 AM
whats everyones take on the mantapart cams with lifters that mantapart makes? http://www.mantapart.com/24tc.html?196,17 jbp has the stage 1 cams for 600 and the lifters for 380 but mantapart has cams with lifters for only 750. thanks and btw im going to order the apexi afc today sometime, anyone think the price cut ones on ebay are junk or what cause you can get them off ebay for like 250 bucks wether retail is at least 350. thanks
Saturday, July 16, 2005 7:38 AM
i was checking out the jbp cams but arent the secret cam swap have more lift?
when u bored that throttle body did u have to match the intake manifold to it thats the first pryority on my list. i want like 62 mm though.
Nick
tired of getting beat by hondas
Saturday, July 16, 2005 7:46 AM
nick renaud wrote:i was checking out the jbp cams but arent the secret cam swap have more lift?
Nick
no i didnt have to do anything to the intake manifold, actually the rsm 62mm measures out to be 60mm and the 59mm tb measures to be 60mm as well soo...you do the math on that one
Saturday, July 16, 2005 11:00 AM
jsunfireGT2000 wrote:whats everyones take on the mantapart cams with lifters that mantapart makes? http://www.mantapart.com/24tc.html?196,17 jbp has the stage 1 cams for 600 and the lifters for 380 but mantapart has cams with lifters for only 750. thanks and btw im going to order the apexi afc today sometime, anyone think the price cut ones on ebay are junk or what cause you can get them off ebay for like 250 bucks wether retail is at least 350. thanks
I don't know about their products but I wouldn't order anything from Mantapart. Worse customer service and you won't get your parts in a timely manner.
Sunday, July 17, 2005 2:03 AM
nick renaud wrote:i was checking out the jbp cams but arent the secret cam swap have more lift?/quote]
the secret cam nets you a sliiiiightly higher lift, but less duration. and you have to perform other head work. the JBP cams are honestly the better way to go in my opinion if you are sticking N/A. go with stage 2.
Sunday, July 17, 2005 8:56 AM
Yeah, I have the Level Zero Stage II cams (same as the JBP cams, they're both ground by Colt Cams just outside of Vancouver) in my LD9, I love 'em althrough extra vibration can be a bit annoying (its kinda funny watching the passenger seat shake with no passenger).
Oh yeah, Level Zero is $50 cheaper http://www.levelzeromotorsports.com
I'm pretty much in the same boat as you, I hope with my current mods, I'll be into the 14s with drag radials.... if not, I guess its time for headwork.
Sunday, July 17, 2005 9:32 AM
So level zero is reputable?
They're a few bucks cheaper, save on shipping I guess.
-M
Sunday, July 17, 2005 12:49 PM
Owen Stampflee wrote:Yeah, I have the Level Zero Stage II cams (same as the JBP cams, they're both ground by Colt Cams just outside of Vancouver) in my LD9, I love 'em althrough extra vibration can be a bit annoying (its kinda funny watching the passenger seat shake with no passenger).
After all the stuff that went down with the ECOTEC cams and how people wanted returns from Level Zero, I wouldn't trust them. I'd rather pay the extra $50 to JBP and know that if something goes wrong they will give me better customer service.
Also, yes they both use the same company to grind the cams but I believe they use different specs on the camshafts. I could be wrong.
Sunday, July 17, 2005 10:27 PM
nope, same damn camshafts... As for what happened with the GP... I'm pretty sure they lost alot of money on that. They are awesome guys, but its kinda hard to give people their money back when they werent making money on it.
I've had awesome customer service, including near-hand delivery to meet my time schedule and those cams are the same specs, the gains are wicked.
Sunday, July 17, 2005 10:35 PM
Owen Stampflee wrote:nope, same damn camshafts... As for what happened with the GP... I'm pretty sure they lost alot of money on that. They are awesome guys, but its kinda hard to give people their money back when they werent making money on it.
The problem is the same with alot of companies. They don't have money to backup with and they spend their profits too fast. When you don't have any money and something like that happends, your pretty much screwed, and that's what Level Zero did...they screwed themselves. They also lost alot of faith in our Jbody community which is their loss also.
I'm sure they are cool guys but they just made a business mistake.
Monday, July 18, 2005 7:59 AM
I too would rather purchase from JBP. they have a proven track record and have the best customer service. Just because you lower your price a couple bucks to overshoot another company doesn't mean peopel are going to go to you. Customer service and knowledge of what the camshaft grinds do is what I want. LZM outright lied to the public and basically this caused then to run the LZM name through the mud.
so i went with JBP, love their products, cars, shop and the people behind them. They're a small business minded couple of guys, just looking to make us jbody guys fast. my hats off to em. ask for Mev or Greg, they're the geniouses over there.
Monday, July 18, 2005 12:56 PM
Henry Mac wrote:I too would rather purchase from JBP. they have a proven track record and have the best customer service. Just because you lower your price a couple bucks to overshoot another company doesn't mean peopel are going to go to you. Customer service and knowledge of what the camshaft grinds do is what I want. LZM outright lied to the public and basically this caused then to run the LZM name through the mud.
Bingo...JBP is great company, price doesn't comphensate for quality of service.
