injector(s) - Performance Forum
injector(s)
Friday, July 15, 2005 2:16 PM
friend of mine was arguing with me about injectors. does the 2200 have 4 injectors or one?
Re: injector(s)
Friday, July 15, 2005 3:05 PM
4 cylinders... 4 injectors...
Re: injector(s)
Friday, July 15, 2005 3:09 PM
thats what i said but he didnt belive me. i didnt see how you could use just one injector but....hes not exactly the brightest bulb in the pack
Re: injector(s)
Friday, July 15, 2005 3:11 PM
no he's not. there are some engines that use 2 injectors per cylinder, but one injector for all four. that just doesn't make any sense.
Re: injector(s)
Friday, July 15, 2005 3:19 PM
i could understand 2 per cyl but exactly what you said one injector just isnt gonna cut it
Re: injector(s)
Friday, July 15, 2005 3:23 PM
alot of ppl that get starved for fuel on a 2.2 add extra injectors since bigger injectors for that motor are hard to come by
Re: injector(s)
Tell your friend to learn a little bit about cars before arguing with someone.
Re: injector(s)
Friday, July 15, 2005 3:26 PM
Rodimus Prime wrote:alot of ppl that get starved for fuel on a 2.2 add extra injectors since bigger injectors for that motor are hard to come by
really? how do you mount the extra injectors
Re: injector(s)
Friday, July 15, 2005 3:29 PM
I believe they are mounted on the end of the fuel rail, on cyl's 1 and 4. And there is an interface box. But I've never seen that system work properly.
Re: injector(s)
Friday, July 15, 2005 8:52 PM
your friend wasn't 100% wrong. The old 2.0L and the 90-91 2.2 OHV were TBI and had only 1 injector.
Gilles
2.3 Ho
Re: injector(s)
Friday, July 15, 2005 8:53 PM
what about the 2.2 right before the 2200?
Re: injector(s)
Saturday, July 16, 2005 2:29 AM
Machzel08 wrote:what about the 2.2 right before the 2200?
Wow I forgot about TBI. The 95-97 2.2 OHV had sidefeed injectors, like I have. NO aftermarket support for them. The 2200 had topfeed injectors, which give tons of aftermarket support for larger flow options. Stupid GM.
Re: injector(s)
Sunday, July 17, 2005 5:54 AM
You know, it's kind of funny about the side feed injector having no support. I believe that injector has been used on some IRL engines. And if you look through Delphi's press releases, they recommend using that injector for racing applications. But they don't give out any part numbers for different sized units.
Don't forget TBI. The early 2.0/2.2 with one TBI injector has ample fuel capacity to supply a mild turbocharged engine, yet the later port fuel injected 2.2 doesn't. Go figure.
-->Slow
Re: injector(s)
Sunday, July 17, 2005 7:21 AM
Mfk-223 wrote:your friend wasn't 100% wrong. The old 2.0L and the 90-91 2.2 OHV were TBI and had only 1 injector.
yup....and the older 5.7L motor was TBI as well.......2 injectors for all 8 CYL
Re: injector(s)
Monday, July 18, 2005 7:03 AM
the pontiac fiero 4cyl has 1 injector. pre 86 that is
DRIVE HARD OR DONT DRIVE AT ALL!!!
Re: injector(s)
Monday, July 18, 2005 10:38 AM
the duke gets no love
Re: injector(s)
Monday, July 18, 2005 1:14 PM
slowolej wrote:You know, it's kind of funny about the side feed injector having no support. I believe that injector has been used on some IRL engines. And if you look through Delphi's press releases, they recommend using that injector for racing applications. But they don't give out any part numbers for different sized units.
-->Slow
interesting...
