Just curious to find out if anyone has bought a set of cams from Comp Cams yet...
If so, how are they? Are they throwing codes? I want to buy these, but don't want to throw a CEL because of them
I've heard funky things about comp cams. some people throw CEL codes some don't have any problems.
Some bust rods and have rough idles too from what I've heard.
sone bust rods?!?!?! are you actually trying to say cams cause someone to break a connecting rod
lmao
But he's thinking about lzm cams.
Let's here from someone with comp or crane cams.
My Car
me want cams
wikkymaster <<-
check out my blogs!
Gov't Auto Auction
How I Stopped Smoking
Easy online cash
UNLIMITED streaming online movies
Sorry Was thinking the wrong cams damnit I hate when I assume the wrong part.
(was more concerned with his posts remaining this month 8.....)
somewhat off topic but I just have to say this.
I know everyone tells you this wikky. but please make sure if you retake that picture your e-brake works.....
I don't want no cavs committing suicide.
and yes. me want cams too. but I don't have 7 hours to install them ><
7hrs? takes me 45 minutes to about 1 hr 15 minutes
LE61T PTE6262 Powered
The only cams I see working for people is J-body performance stage 1 and might have a couple people have the stage 2 work ok but I think they throw atleast 1 code. I have the stage 1 and no codes thrown cause of the cams but I did start running lean but no lean code was thrown.
i have JBP's stage 2 eco cams and as long as it doesnt idle for a long time i dont see any codes
04 sunfire auto, mid 15's n/a, and still going
You know JBP has a fix for that now. They reflash the PCM and according to them, it eliminates all codes on the Eco.
-da chinchilla
<img src="http://registry.gmenthusiast.com/images/jiggamon/avatar15569_2.gif">
a little over priced and inconvienent you have to send them a ECU and they reflash to and then send it back to you and then you hope that it works right and if not you have to send it back again a big pain in the ass for $550
04eco (roy) wrote:a little over priced and inconvienent you have to send them a ECU and they reflash to and then send it back to you and then you hope that it works right and if not you have to send it back again a big pain in the ass for $550
Exactly!
so stage one jbo perfomacne cams it is
unless someone has some info on the comp cams
I heard the Crane cams are ok--no codes. But I really want some info on these Comp Cams.
in all honestly i would go with the stage 2's if you go JBP. the CEL isnt that bad and doesnt put the car into limp mode or nothing either. but iti s your money and choice haha
04eco (roy) wrote:in all honestly i would go with the stage 2's if you go JBP. the CEL isnt that bad and doesnt put the car into limp mode or nothing either. but iti s your money and choice haha
If your a street only car and take your car to inspection, you don't want to spend $ on cams that will throw codes, you personally don't want your check engine light on all day long. JBPs Stage 1 perfect for a street only/daily driver car. Stage II's is if you really don't care about the code but you could run into problems with knocking...that's a possibilty cause the computer goes "hay-wire" when the profile is slightly higher. That's my opinion.
Need Turbo cams, with long ass duration and small overlap.
Who can make that.
Lift could be a bit higher since I might rev it up to about 7000RPM or so??
Anyone know where I can get these custom ground??
Best time:"""11.946""" @ 114.73 mph @17psi 1.83--60"
11 second daily driver!!!!
Race Related 727-561-9440
Shop of choice for your 11 second J body!
Also, built bottom end and or top end LSJ and L61's available.
13's
----12's
----11's
----10's
SunCavi_L61T3/T04E wrote:Need Turbo cams, with long ass duration and small overlap.
Who can make that.
Do alot of reasearch on how cams work with motors/computer and call up
Colt Cams (604-856-3571) and tell him exactly what profile you want. By the way they are located in Canada so prepare for a long distance call if your in the US. You can check out their website also
www.coltcams.com. When you call ask for Jeff, he's the owner and a very nice & helpful guy.
i like what you have to say about jbp stage 1 cams honda killa where do i find them and what else is needed for them to perform
travis ficken wrote:i like what you have to say about jbp stage 1 cams honda killa where do i find them and what else is needed for them to perform
The beauty about the stage I cams is that you don't NEED any other modifications to have them run properly. They are street cam profile which is mainly for daily drivers/weekend warrior types who still want to pass inspection. For more info go to their site:
www.jbodyperformance.com
Good luck with your decision
By the way, JBP is based in Canada so if you want to call them prepare for another Long Distance call if your in the states...just a little 411
My JBP stage 2's do not throw codes at all. Awesome cams.
I would have posted if I had seen this... I have the Comp Cams and was one of the first ones to do so...
I have NEVER had a code thrown. AND I toasted an Aurora in an s-turn and he couldnt catch me on the straight-away afterwards... I'm pretty happy with my performance from them. (Obviously, I have other things done as well.)
RHD CavFire wrote:I would have posted if I had seen this... I have the Comp Cams and was one of the first ones to do so...
There is your answer red04cavy
No one really posted any type of results of those cams so we had no idea how they ran. Glad you did...you learn something new everyday.
