leaking is back: ETS and CE lights come on...why? - Maintenance and Repair Forum
Sunday, August 28, 2005 11:11 PM
ok the dripping is back, and im almost positive it is the tranny fluid now. the check engine light and the ETS OFF light both come on, and the shifting feels wierd. isnt the ETS the traction system for the tranny?
anyways i dont know if its the rear seal that you have to pull the engine for, or if its just the seal around the tranny pan. the drip is comming off the corner of the tranny pan......so.....
what do you guys think?
-Cameron (CaliforniaCavalier)
Girls make me mad and break my heart, but my car is always there for me.
Re: leaking is back: ETS and CE lights come on...why?
Monday, August 29, 2005 5:33 AM
I don't think the CEL is related to your leaking trans...
Have you pulled the code?
<img src=http://registry.gmenthusiast.com/images/reddevil/Devil.jpg>
Monday, August 29, 2005 8:29 AM
havent pulled any codes yet, but if there is a leak of oil or tranny fluid, will it throw a code for sure? i didnt think it threw codes for stuff like that.
Monday, August 29, 2005 5:15 PM
First things first... always check the codes... that's why the light comes on, right? That's why it's there.... to tell you what is wrong with the system.
There are many transmission codes... a huge list. It could be as simple as a low fluid level (have you checked that yet? It's a pain to do, but could be all that the problem is)
ETS = traction control... yes, transmission.
However... I notice in your registry you have a B&M Shiftplus.... that increases the line pressure... which will turn off the ETS.... so that's normal, depending on the setting of your B&M Shiftplus.
<a href="http://www.lenkorules.com/"><img src="http://members.shaw.ca/jlenko/sig/redsig.jpg"></a>
Monday, August 29, 2005 7:46 PM
You may have a leaking trans cooler line at or near the trans, but check your codes like^^^^^ said.
Thats Him Officer The WICKED One.
Tuesday, August 30, 2005 11:42 PM
i took it to the shop, ended up being a nice little hole in he corner of my tranny pan.
i must have hit it on somthing, because it left 3 little pebbles inside the bottom of my pan.
the ETS and CEL are still on, but im assumming they stay on for a few days even after the problem is fixed, until the ECU resets? is that correct?
Wednesday, August 31, 2005 6:07 AM
did you even get the codes checked?
Friday, September 02, 2005 1:50 AM
nope, friend told me to wait a while and see if they go off, and they did. the next day after i fixed my tranny the lights went off.
Friday, September 02, 2005 3:41 AM
look deep under the car, and there should be a switch on the lower firewall on the passenger side, the switch reads "broken" and "fixed". it's probably flipped to broken, very common on these cars, then flip it to fixed, should run good as new.
