Anyone know a good trick to get that water outlet passed and on over the hard line, i tried some soapy water, lube and cant get it past the o ring which i replaced with the one thatcame in the box with the part.....please help.
Just pull hard? Shouldnt be stuck that bad
Have a nice day.
A flat head screw between the hose and metal water neck, and wiggle it all the way around, keep going deeper and deeper.
:::Thats what she said:::
that did end up working besides i used a pry bar! thanks man
I would have just put a touch of oil on it...
Wiggle, twist and lubricate to put on. I found that when it's anything but hot out that a hair dryer or heat gun helps tremendously with rubber hoses especially when they are on the more fragile plastic connectors.
