Engine won't turn after injector job - Maintenance and Repair Forum
Thursday, June 26, 2008 10:38 AM
Today I parked my car, which is a 2.2l 1995 sunfire, removed the injector bracket, removed an injector, changed the o-rings (it was leaking). After that I put everything back together, try to start the engine. It turns like 3 times and after that I hear a "blocking" noise. Now the starter won't turn the engine, all I hear when I turn my key to start it is : "tok". My car has a manual transmission, so I tried pushing it with the help of somebody, get in the car after a decent speed, and release the clutch pedal on the first gear. Tried that about 4-5 times. Car won't even try to start. It's like something prevents the engine from turning... I need your opinion please. Thanks!
Re: Engine won't turn after injector job
Thursday, June 26, 2008 10:46 AM
sounds like hydrolock.
pull your spark plugs and try and crank it.
Edited 1 time(s). Last edited Thursday, June 26, 2008 10:46 AM
Thursday, June 26, 2008 11:12 AM
Thanks, I'm going outside to do it right away.
Thursday, June 26, 2008 12:26 PM
You were right. I took off all 4 plugs, removed the injector/fuel pump fuses and cranked it until I did not see anything coming out of my cylinders. Now the engine starts, but it's hard as hell to start it, and I have to use the throttle or else it stalls. Also, I think my car is not safe for roads, because when I drive it, it emits a THICK and white smoke, and it runs very rough. I have new bosch platinum spark plugs in it, and they seem already blackened. I don't know if the fuel into the cylinders could have done that to them, and I don't know if I have to change them either. I would like some advice on how to get rid of the white smoke/rough engine. Thanks in advance!
Thursday, June 26, 2008 12:29 PM
did you change the injectors?? sounds like it is either running rich, or you have another problem....like blown head gasket...
Thursday, June 26, 2008 12:38 PM
I did not change the injectors. Everything was working fine except the injector leak before the hydrolock. I am not a mechanic, but I can clearly see the gaz coming out of my exhaust manifold's leaky spot. So I guess the white smoke is gaz... but why? Can it be the plugs?
Friday, June 27, 2008 6:24 AM
white smoke is coolant
black smoke is gas
blue smoke is oil
Friday, June 27, 2008 12:36 PM
hydrolock is caused by....you guessed it.....water. white smoke and hydrolock would lead most people to beleive blown head gasket. might be just a coincidence that it happened after you fixed the injector.
Friday, June 27, 2008 12:38 PM
kind of....hydrolock is caused by liquid. it does not have to be water/coolant though. although that is probably the most common occurance, but i have seen fuel related hydrolock before as well.
Friday, June 27, 2008 12:48 PM
What kind of fluid was coming out of the spark plugs when you pulled them? gas or antifreeze? You could have a blown head gasket or maybe an injector is stuck open. Judging by smoke color I'm going to lean towards head gasket
Saturday, June 28, 2008 7:58 PM
The car is up and running. Thanks for all the input. Turned out the white smoke was fuel. I dissasembled the injectors again and I found a cracked o-ring that let fuel go straight into the cylinder, causing it to hydrolock again and again. I fixed that, changed the plugs for good ones, and then I drove the car revving it like hell to get all this white smoke out of my exhaust system. After a day of hard driving, it all went back to normal. I'm glad I didnt damage my car. Thanks again!
Saturday, June 28, 2008 8:15 PM
Do yourself a favor and change the oil ASAP. There is a good chance that there is gas mixed with the oil if thats the case. You will wipe out your bearings if you have the gas in the oil.
