Engine light on, manual code check? - Maintenance and Repair Forum
Sunday, February 17, 2008 3:59 AM
Just wondering if it is possible to get the code or problem manually without a reader? I recall on my old Plymouth Sundance all you have to do is turn the key back and forth like 4 times and then the engine light would flash x number of times and that was your code number!! Can we do this with a Cavalier? Mine is a 2000. Thanks
Re: Engine light on, manual code check?
Sunday, February 17, 2008 7:32 AM
nope. you need a scanner for 1996+.
Sunday, February 17, 2008 12:49 PM
if you go to autozone they can check diag. trouble codes for free
Sunday, February 17, 2008 7:07 PM
Thanks guys. John, Autozone is USA only I am in Canada maybe my local parts place will do the same, I will call on Tuesday and see. Thanks again.
Sunday, February 17, 2008 8:17 PM
im from Ontario, i called around crappy tire, partsource none of those places do it, the best thing you can do is check ebay and buy a cheap OBD2 scanner they are like 20$ instead of 50$ at crappy tire. Its a useful tool to have..
Monday, February 18, 2008 6:51 AM
Thanks Jacob I'm Ontario also and you just saved me some footwork!!
