shifter loose - Maintenance and Repair Forum
shifter loose
Monday, July 31, 2006 5:15 AM
Well yesterday I took my sisters 99 sunfire gt out for a drive and her shifter was nice and tight and close together hell I almost missed gears , on my 95 I can throw my shifter all over the place . Did they change something over the years ? is the gt more short ? or is mine just done lol ?
Re: shifter loose
Monday, July 31, 2006 12:01 PM
Mine did the same thing when the shifter linkage was starting to wear, it has a "cup and ball" joint on the bottom of the shifter aswell as on the transmission, and as this wore out more mine got more and more play in it, eventually I had to replace the linkage as the cup would just pop off the ball sometimes, now its back to being nice and tight
Re: shifter loose
Tuesday, August 01, 2006 2:57 AM
Did she buy it used? If so it could have had a short throw put in before she bought it...
Re: shifter loose
Tuesday, August 01, 2006 4:20 AM
nope she bought it right off the showroom floor , so the cables can be changed does the part with the ball change or do I need to change the entire system , I think a new B&M might be in order lol
Re: shifter loose
Tuesday, August 01, 2006 5:21 AM
I love my b&m short throw...
I know before I put mine in everything was very loose...
Re: shifter loose
Saturday, August 05, 2006 1:46 PM
Unfortunatley I was not able to just change the cup or the ball piece, I tried searching but it turned out to be a dealer only part, and you need the whole cable
Re: shifter loose
Thursday, April 26, 2007 8:29 PM
I seem to be having the same situation with my 99 Cavalier (2.2L). One evening I was trying to accelerate a bit quickly and when I tried to shift into second I heard grinding and then the stick gave way and there was no second gear. However my other gears still worked; but I quickly learned that all my gears (including second) worked fine. But anytime I try to shift too quickly or with too much force the shifter seems to slip and I can't get a gear. Do you think this sounds like the ball joint? If so any idea how much a new part would cost? Thanks for any help.
