96 Grand Am 2.4 in 99 Cav?? - Maintenance and Repair Forum
Thursday, April 13, 2006 3:19 PM
Buddy of mine needs to replace motor from 99 z24. Was wondering if its possible to replace it with the 2.4 from 96 grand am. I know some changes were made in 1999 to the LD9 and there are actually 3 different LD9 part numbers. Does anyone know what changes were made and if they can be swapped. If not, what motors will actually fit the 1999? only 1999-2002? Need some engine experts on this one!! Thanks in advance!
Re: 96 Grand Am 2.4 in 99 Cav??
Friday, April 14, 2006 3:41 PM
Well akJBody :
The engine block on 96 Grand Am 2.4 in 99 are the same, The upper intake manifold and emission system with be different, In which if you have to a bit of modding to get things to work, You will need pcm from the 96 grand Am possibly wiring harrness, Its quite a pain. Just better off getting another 2.4 engine that 99. Ive done a few conversions with 88 tempest 2.8L V6 engine& tranny swap in to cavalier 2.8L V6 I had to replace the PCM / wiring harness, Also change the transmission module, For this swap, Too much trouble for it was worth.
Good Luck
keep Us updated.
