car sluggish? - Maintenance and Repair Forum
car sluggish?
Sunday, April 02, 2006 10:41 AM
i got a 98 z24 and it has 119000 miles on it and it has been feeling sluggish latley. i changed the plugs yesterday and that seemed to make it worse. do you guys think my cat could starting to clog up?it doesent back fire or any thing but it just feels weak as hell
Dark for fear of failure
An inner gloom as wide as an eye and fermenting
Roiling hate
Death gripped my veins
Unveiling rancid petals
Flowering forth foul nectar
The space between a blink and a tear
Death blooms.-mudvayne
Re: car sluggish?
Monday, April 03, 2006 12:33 AM
try replacing o2 sensor
Re: car sluggish?
Tuesday, April 04, 2006 6:28 PM
also it is running lean but it doesn't throw a code for the o2 sensor . if that matters
Roiling hate
Re: car sluggish?
Wednesday, April 05, 2006 5:40 AM
how do you know its running lean?
Re: car sluggish?
Wednesday, April 05, 2006 12:57 PM
Quick qustions: did you gap the plugs? pcv filter, oil, has the engine light (ever) come on?
http://img86.imageshack.us/img86/4235/jim25ek.jpg
Re: car sluggish?
Wednesday, April 05, 2006 2:37 PM
which plugs did u use.. hopefully ac delco?
Re: car sluggish?
Wednesday, April 05, 2006 2:51 PM
Check exhaust backpressure.
If an O2 sensor fails you will get a code, if no CEL it isnt your problem.
Backpressure in the exhaust, to much actually will cause sluggish problems.
Not enough fuel can to, check fuel pressure.
Plugs are gapped correctly?
Re: car sluggish?
Wednesday, April 05, 2006 3:05 PM
id say its the way you gapped the plugs that made it worse. And as far as sluggish, do you have exhaust leaks, or maybe you should run something like seafoam?
And as far as the plugs go, arnt these the ones?
Part # 41-948 - SPARK PLUG, PLATINUM PLUG
and dont we gap at .060?
98' Pontiac Sunfire SE
Re: car sluggish?
Friday, April 07, 2006 7:58 PM
Rob S wrote:Check exhaust backpressure.
how do you check the exhaust back pressure?
Roiling hate
Re: car sluggish?
Friday, April 07, 2006 9:40 PM
called an exhaust back pressure gauge, screws into an O2sensor bung... do it when cold, the ecm won't look for the 02 sensor when the car is cold.
Re: car sluggish?
Saturday, April 08, 2006 8:41 AM
Supra90mkiii wrote:called an exhaust back pressure gauge, screws into an O2sensor bung... do it when cold, the ecm won't look for the 02 sensor when the car is cold.
Yeah should below at 1.5psi or belwo, lower is better.
Make sure to rev the engine to say 3500RPM, and watch the gauge. I have seen it before with a Grand Am. It was sluggish above 40mph, turns out exhuast pressure was fine below 40, but when it hit 40mph it was 6PSI, the car couldnt remove what was coming in, cat fell apart and was creating a restrition.
Turns out the cat was shot.
