will be doing fiberglassing myself this summer. interested in how you will make out. looks good so far imo
Just make the extra effort to keep it smooth.
____________________________________
Primer Counts as Custom Paint Right?
BTW: This is my Sig.
Good start. Just have to remember to rough up the plastic pieces with some 36 grit before you wrap it in fleece so it will stick. A little trimming and some sanding and your good to go. If you are looking for tips and what not, go to
http://www.fiberglassforums.com there is a ton of info on there.
KevinP (Stabby McShankyou) wrote:
and I'm NOT a pedo. everyone knows i've got a wheelchair fetish.
A little update.
Again.. phone pic and crappy lighting!
whats going on with the corner on the right one?
Yeah...... I forgot to do the whole sanding of the plastic thing lol. So im just gonna spread some resin on that area so its smooth. But that spot has been sanded now. The rest of it is stuck real good.
heres a test fit
I would have just put the tweeter mount in and gobbed duraglass on
Always tear fiberglass mat, never cut it. It will allow the edges to interlock better.
It me it looks like the glass isnt sticking too well to the plastic. I would pry it off and redo it. Also what are the plastic circles from?
Tinkles
2003 Cavalier 1SV
Bagged and Blown
I was trying to pop it off and sand the piece down then resin the area and stick it on again, but i cant seem to get it off so i would say its good. I just dont know what to do about the holes where the screw goes. Any suggestions?
You could get a x-mas tree style push in clip from the parts store, cut out the screw boss on the original piece and glass in the x-mas tree. Then you will be able to install remove them without a screw driver. Or you can just trim out the screw boss and blend it into the fiberglass, thats what I do when I wrap those pieces in carbon.
I think i might just take the x-mas tree clips and put them over the hole i drilled to get to the screw. Im fine with a small push clip. Its getting painted black anyways, shouldn't stand out too much.
A little bondo.
Should be done in a little bit.
it looks like one of the pods flsres out for the tweeter and the other has the hole flush.
they will hold the tweeter differently thus looking out of place. needs more work before install.
Luis Marroquin wrote:whats the hole for?
i assume you mean the little holes?
those are for the screws that hold the panel on the door
Your lack of imaging makes baby jesus cry.
im·ag·ing (m-jng) KEY
NOUN:
1. The visual representation of an object, such as a body part or celestial body, for the purpose of medical diagnosis or data collection, using any of a variety of usually computerized techniques, such as ultrasonography or spectroscopy.
2. Psychology The use of mental images to influence bodily processes and to control pain, or to achieve a goal that one has visualized or imagined.
That's the answer to your question, but why do I get the feeling you still have this look on your face?
FOR SALE
Haha, I hope you're not serious.
by imaging... they mean the fact that ur tweeter points at ur ballz, not ur ears lol
and are too far away from the woofer. You'll hear a delay as well.
