im asking this in suspension cus i know you guys know the most about air compressors
what i want to do is put a LOUD air horn in my car..one that requires an air tank with about 120psi....now i dont know much about air compressors and instead of buying a 500$ kit i was gonna try to build it blah blah blah...so could one of you guys maybe point me in the right direction of an air compressor and tank that i could use for that or at least educate me on them..thank you
just get a small saucer tank or a 2.5gal tank and get a small viair compressor. Like a 280 I think it is
The 280 is listing for $115 on EBAY.
I wouldnt even use that pancake tank. TO big for this app. 1 or 2 would be fine.
Go ahead and run a 145 psi switch to make sure its damn loud.
I am all that is man
mesra wrote:im asking this in suspension cus i know you guys know the most about air compressors
Um, you know you can do a sixpack if you want? or just get a heavy duty Air horn compressor for about $20. BTW a 6 pack is 6 of those HD air horn compressors feeding 1 air line.
Also for your safety, when you test to see if your compressor(s) are working, make sure the horns are not hooked up. Its an easy way Not to go deaf.
And why are you trying to copy me?
