hey i just finally saw the specs for this thing EcotecŪ 2.4L DOHC, 4-cylinder, SFI, aluminum (177 HP [132.0 kW] @ 6600 rpm, 166 lb-ft [224.1 N-m] @ 4800 rpm) i am wondering if anyone has researched doing a swap with this engine @!#$ ill keep the cavy if i can do that. by the way i got the info of pontiac.com the new solstice. sorry if im late and you already now this.
Its not out yet. It looks like a good motor though. Heres a good link for it:
2.4 Ecotec
crackajax wrote:Its not out yet. It looks like a good motor though. Heres a good link for it: 2.4 Ecotec
I bet you that months after it comes out, you'll see some high powered all motor ecotecs just for the fact that it has VVT (Variable Valve Timing).
Does anyone think that it would be possible to hook up the eco s/c kit to this? Was worried about the electronic throttle but the kit comes with another one and a reflash would fix this right?
Rich
rich222 wrote:Does anyone think that it would be possible to hook up the eco s/c kit to this? Was worried about the electronic throttle but the kit comes with another one and a reflash would fix this right?
I was thinking this. It would be a nice engine...
NJs Honda Killa wrote:I bet you that months after it comes out, you'll see some high powered all motor ecotecs just for the fact that it has VVT (Variable Valve Timing).
Is that similiar to Toyota engines?
Rob
Sold 2/2/05
That pdf link above says 170 HP not 177.. Which is the real one? I like the number closer to 180
2012 numbers - 4SPD
AUTOMATIC!!
i heard that you either need the GM ECM for the 2.4eco or you'll have to use a stand alone.
Yes, some Toyota engines have VVT
That's how it goes for most swaps.
alot of manufacturers have vvt, vct, etc etc
![](http://img16.imageshack.us/img16/8102/09camryse3r3.jpg)
Not unintentionally accelerating since 2009!!!!
from what i heard, this engine is bored out from the same block as the 2.2 eco.
boosting a bored out engine is not a good idea since the cylinder walls are thinner
![](http://i134.photobucket.com/albums/q109/99redz24/camarosig.jpg)
the 177 figure is the engine in the soltice
Hmmmm Looks good.
we'll have to wait and see. Who do you think would be the most likely jbo member to haul off and try to do a swap?
Premium since Tuesday, May 24, 2005 10:19 Pacific time. Support the .org people!
i was lookig into doing a head swap, or the 2.4 interals, to make my 2.2 ecotec have vvt
i dont think that will work youde need the ecu also and i dont think the 2.2 and 2.4 ecu besides the vvt are going to be the same...
![](http://registry.gmenthusiast.com/images/mattlb0619/cavisig.jpg)
It would be nice if that thing was underated like the Cobalt SS engine....
from what i heard it is closer to 200hp at the flywheel
![](/global/images/emoticons/jbo.gif)
that would be a sick swap into a cav.
see ya!
novaracer wrote:from what i heard it is closer to 200hp at the flywheel
Acutally it's advertised as 170 HP crank
ROBZ IL CAV wrote:NJs Honda Killa wrote:I bet you that months after it comes out, you'll see some high powered all motor ecotecs just for the fact that it has VVT (Variable Valve Timing).
Rob
VTAK! (VTEC =
Variable Valve
Timing and
Electronic Lift
Control System)
Toyota VVT-i
Ford Zetec
the list goes on
I think GM could call it ECOTAK
Didn't know the Zetec's were VVT...you learn something new everyday
RAKSJ04 wrote:i was lookig into doing a head swap, or the 2.4 interals, to make my 2.2 ecotec have vvt
that wont work. VVT is not a bolt on
99redz24 wrote:RAKSJ04 wrote:i was lookig into doing a head swap, or the 2.4 interals, to make my 2.2 ecotec have vvt
It should work actually. Would require a new ECU and alot o wiring changes.. Its just lie swapping a vtech head on a honda.. Same stuff... But in theory is should work.
(But i dont think is worth the money and time)
When GM put out the 2.2l ecotec motor, they said it was made to take new technologies such as VVT. We know that it has to do with the lash, but it will be possible to do. If you do it, you might need to switch to an electronic TB, beacuse i believe all 2.4s will be like that. I'm interested in getting VVT in my car, i will look into it. We have to wait till it comes out. It should be out soon.
