Alright so I'm getting ready to get the GM charger kit for my 02 z24. My questions concerns the engine. I was originally planning on going turbo and building up the engine, but I decided I rather go charged. Anyway, my question is would lowering compression in the engine help out with the supercharger in the same way it helps with a turbo. I'm still learning so I'm not quite sure about it. I want to eventually do some engine work to make it stronger either way, so I was just curious if going to a lower compression will help or not. Thanks for you help.
Yes. Lowering the compression helps in likelyness of detonating and tuning as well. 9:1 compression is a good compression to run under boost.
With the charger I would go with 11:1 compression. Even 11.5:1. You're limited with the charger so you can up the compression to compensate. I'd rather have water injection with 11:1 with the charger than 9:1.
Gilles
2.3 Ho
with the GM charger you dont want lower compression... stay with the pistons you have or if any thing go higher compression...
The First Twin Charged jbody
blue car (R.I.P) - 240whp @7psi..
silver car - 305whp 315lbs.tq @15psi (91 Octane) or 420whp & 425lbs.TQ @20psi (94 octane+Alcohol Injection)
All dynos run on a Mustang dyno
