^problem with rear led bulb light..fast turn signal - Audio & Electronics Forum
Saturday, August 11, 2007 8:11 AM
hi
i bought a set of led bulb light for my taillight..but when i installed them they are flashing too fast....
i need to fix this..
the guy at bestbuy sold me a electronical bobin for light...it look like a relay...but it's not..
i don't know where i need to switch that part on the car..
the guys told me its under the dash...
but where? I CAN'T find it..
does anybody could help me please !
Re: ^problem with rear led bulb light..fast turn signal
Saturday, August 11, 2007 1:51 PM
that is a common problem.
the reason for the "blinkers on crack" is due to the fact that the LED bulb places a lower load on the circuit, making the flasher think that the bulb is burned out, meaning that it blinks faster.
there are 2 fixes for it
1) Load resistors (not my #1 recommendation, but if placed away from something that will melt easily, it will work just fine)
http://frickinbrite.com/catalog/product_info.php?cPath=44&products_id=113
2) Electronic flasher
http://frickinbrite.com/catalog/product_info.php?cPath=62&products_id=295
or http://autolumination.com/equalizers.htm (ep27 flasher)
Saturday, August 11, 2007 6:01 PM
i would also (and have used) the replacement led flasher. i would recommend this, because honestly, it doesnt cost any more than a regular replacement flasher, and it is actually the easiest to do. no chance of it melting anything, either.
car audio noob since 1984.
Saturday, August 11, 2007 10:35 PM
yeah thats what i bought...
a electronic flasher...but mine have only 2 pin..the guys told me thats the good one for my cavalier 02
but where i install it??...it supposed to replace my oem part..!!
Sunday, August 12, 2007 12:23 PM
im fairly sure all 95+ cavs and fires had the ep27 style... it needs to have 5 pins on it. the ones for leds are specifically made not to see a load. they flash at the proper rate at all times. your parts guy was only selling you something you didnt need, happens all the time. take it back and get one of the ones kardain listed. i checked the price on a stock replacement flasher today and it runs $16.
Sunday, August 12, 2007 2:10 PM
correct. our cars are 5 pin.
Friday, August 17, 2007 2:52 PM
98+ models should be located on the brake pedal bracket above the steering column under the dash.
Friday, August 17, 2007 3:59 PM
^^ thats where mine is on my 96. i dont think they moved far after 98 either.
