Port the 2200 Throttle Body?? - Performance Forum
Tuesday, August 14, 2007 8:06 AM
i just got a spare head and tb (thanks daniel) and i was wondering if i should take the tb and port it open a bit more. i wont be doing this of course but will take it to a local shop. im doing a turbo build so i figure opening it up a lil bit more cant hurt. i was thinking around 59mm... what do you all think? and is there anything i need to be sure to tell them?
Re: Port the 2200 Throttle Body??
Tuesday, August 14, 2007 8:23 AM
On an n/a motor I have a 56mm tb and it helps a bit. 59 for boost should be a good upgrade, so long as it goes into the manifold smoothly, you might want to open the throat o the manifold as well.
Tuesday, August 14, 2007 8:54 AM
how do you port plastic? i figure trying to port the intake manifold would cause it to burn up and melt.
Tuesday, August 14, 2007 8:59 AM
I used a dremel and went slowly with it, I had a metal wheel that looked like a gear that was for cutting, i used that first and took off some plastic, then to make it smooth, I used 2 grades (a rough and a fine) of scouring pad type material and smoothed it all together, I also portmatched it to my ported head. Im still waiting to install it, but it looks good and the inside of it is all smooth where I worked on it
It did start to smoke and melt a bit when i pressed too hard with the finishing bits, but if you press lightly and go slow, you should be fine.
Tuesday, August 14, 2007 9:20 AM
or you could buy an intake manifold.
Tuesday, August 14, 2007 9:58 AM
When you port th TB, dont you need a new butterfly or whatever you call it that opens in the TB?? I was thinking about doing it to mine but need some info first. I think the car would'nt idle right if you didn't have the right size.
Tuesday, August 14, 2007 3:34 PM
whiteboyz24 wrote:or you could buy an intake manifold.
no one i know makes a intake manifold for the 2.2l 2200 ohv
