Worn rings? - Performance Forum
Worn rings?
Wednesday, December 20, 2006 12:56 PM
In an effort to figure out why my car lost a whopping 25HP at the dyno this summer, I've been running a bunch of diagnostics as of late.
I hooked up a vacuum gauge and when accelerating (say 1000 to 3000 to get up to driving speed) my vacuum reading goes to 0.
I think this is worn rings, am I wrong?
Also, how much is that gonna cost?
Re: Worn rings?
Wednesday, December 20, 2006 2:29 PM
the proper way to check for worn rings is a compression test or leak down test
the manfold vaccum will drop when you crack the throttle especially WOT
Re: Worn rings?
Wednesday, December 20, 2006 3:00 PM
Was it a hot day that you dyno'd?
Was it high humidity?
Was it the same dyno you used the first time?
Did you have a check engine light or SES light?
There are a lot of reasons your two dyno's could be 25hp off, I wouldn't go tearing into the engine just yet.
Re: Worn rings?
Wednesday, December 20, 2006 5:14 PM
at WOT engine creates no vaccuum..
Re: Worn rings?
Wednesday, December 20, 2006 5:25 PM
......um. Every one is being too nice.
First, read some BASIC books on theory of the internal combustion engine.
Then
Think.
I would have to say there is nothing wrong, besides maybe, bad gas, dirty air filter, or a loose nut behind the wheel.
---sorry that was mean.
But really, unless there is a drivability issue, you’re golden.
Chris
'02 Z-24 Supercharged
Re: Worn rings?
Wednesday, December 20, 2006 8:18 PM
Hmm.
From what I've learned, it seems like it shouldn't drop down to 0 but more like 3 or so. Maybe I'm wrong. Probably
Anyway, it's idling at about 15"
Re: Worn rings?
Thursday, December 21, 2006 3:49 PM
Idle should be around 20" of HG, at WOT you want to get ZERO IE atmospheric presser, anything less is robbing power,
Really, get a book and learn it if you really want to play with gauges and worry.
Otherwise just drive it.
Chris
