I have a small question on the installation of the 2.3 HO intake manifold on to the sunfire 2.4GT.
Hear it goes do i need to get an adapter plate to attatch it or can i not use one?
And if so why?
thank you
You dont HAVE to, but its recommended. The reason being, it makes the swap that much easier, it also helps the air transition from the oval shape ports on the manifold to the bshape ports on the head. Before the flange was around you had to some how make the manifold have bshaped ports by adding material and grinding down to make it match. So thats really the only reason you need the flange is to make the ports match up.
Click the banner to enter the best Quad4 & Twin Cam site on the internet.
the manifold would also get extremely hot due to being connected to the head/block. The adaptor flange that Chris Fontana sells reduces the heat transfer to the HO manifold.
cmunn99gt wrote:the manifold would also get extremely hot due to being connected to the head/block. The adaptor flange that Chris Fontana sells reduces the heat transfer to the HO manifold.
That is only with the new one... the old ones where Steel weren't they??
Knowledge about everything and yet an expert of nothing!!
Jack of all trades.
the older adapters I used to sell where aluminum.......
the adapters make the job so much easier.
SPD RCR Z -
'02 Z24 420whp
SLO GOAT -
'04 GTO 305whp
W41 BOI -
'78 Buick Opel Isuzu W41 Swap
Where do I get one of those adaptors?
Thanks
- Darren
gmtunerz.com -||- phewes.snowpants.org -||- zukiworld.com
Silver_00ZED24 wrote:cmunn99gt wrote:the manifold would also get extremely hot due to being connected to the head/block. The adaptor flange that Chris Fontana sells reduces the heat transfer to the HO manifold.
thats why I said the one that Chris Fontana sells
Phewes wrote:Where do I get one of those adaptors?
Thanks
Chris Fontana has the adaptors, last I read he had 12 of them left...
I would consider an exhaust manifold to get extremly hot. The ho manifold without the flange does not get that hot, just about as hot as most other parts under the hood. But with the flange, the ho manifold is almost always cool to the touch.
urweak wrote:cmunn99gt wrote:the manifold would also get extremely hot due to being connected to the head/block. The adaptor flange that Chris Fontana sells reduces the heat transfer to the HO manifold.
fair enough, it gets hot, which is bad
