Ok so I have an 04 cav. I'm I. The middle of doing a trunk swap and currently have a painted tail bar on the stock 04 trunk. Do you think use img a aftermarket pair of outside tails with this color matched painted tail bar would look ok?
Yah or Nah?
![](http://i158.photobucket.com/albums/t116/psyclownnetz/6E6DF5E5-3CC7-45E3-AC4A-FA04717700C9-1410-000000992BBD0C3C_zps6bbcc3b2.jpg)
Straight lines are over-rated In My Opinion =]
Stock tails, Toyo tails, or bust.
________________________________________.
Still not low enough for a signature.
Ok so I got 1 opinion, anyone else?
Can't see the pic,are you talking of the 03+ inner lights? Then no, if you are talking about.the rear center spoiler then yes
Modding my j since I found the org
I like the look of your tails, but I'm with Twenty4z here, Toyo tails are amazing, or stock 95-02's. I myself am looking for a trunk and tails for a swap onto my 03
Oh shizza that's incredible, I never thought that was swappable! Like I said tho I'm In the middle of a trunk swap, I'm just bored and was trying to make it look different till the trunk got painted lol =]
The pontiac back end doesn't look bad. It's better than the dog@!#$ one that's OEM on the chevy. A trunk swap isn't the best option in my case since Orange Metallic II wasn't available pre 03. As much as a repaint would cost, I may as well get the OEM filled and tocuhed up, Maybe if I can get a decent deal on the sunfire set. Myother worry is there not being enough room for the OEM spoiler.
im not a fan of the 03-05 tails i much prefer the 00-02 tails with the z24/lss 00-02 spoiler, on any third gen
John Lenko wrote: It is bad. Stop. Now. Bad. Bad bad. Bad bad bad.
...j
You could try what I did ,paint stock tails to match body color and tint them !
BLACKMANTIS
I was going to and leave the raise circle parts inpainted but i dont have reducer for the paint i have, and when i get the reducer om just gonna paint my trunk in swaping in.
Yea so boredom got the best of me lol
Next the trunk will be swapped to go with it.
teal wrote:The pontiac back end doesn't look bad. It's better than the dog@!#$ one that's OEM on the chevy. A trunk swap isn't the best option in my case since Orange Metallic II wasn't available pre 03. As much as a repaint would cost, I may as well get the OEM filled and tocuhed up, Maybe if I can get a decent deal on the sunfire set. Myother worry is there not being enough room for the OEM spoiler.
I too previously installed the sunfire bezel with the 03 spoiler and there is a small gap of clearance between the two. I then did it right and swapped to an older trunk and had is sprayed to match the car. It only ran me about $300 once finished and it was well worth it. It pays to save your money and do it right the first time rather than continuously pumping money towards cheaper/temporary mods, a lesson that has been hard for me to overcome.
Also, in my opinion it looks more appealing to remove the 03 lights and replace them with 95-02 and fill the 5 remaining holes with painted one way clips rather than attaching another bezel. I wouldn't do it that way but if you're looking to save money and want the 03 bezel delete, that's your best option.
Just waint to get some reducer and clear coat then in good to spray =D
Waitin*
