My uncle painted the bottom of the doors on my car the other day, cause he owns a body shop, and its black so its easy to match , but wile he had it in the garage he put a pinstripe on it without aking me and its yelow and red, it looks really bad on a black car, so i was wondering how hard it would be to remove it if its only been on there a couple days, and would it hert my paint? Thanks
Is it painted on or a decal? If its a decal, it should be pretty easy to get off. Just start pulling it off. Use goo gone/adhesive remover on areas if needed. A heat gun on low may help too. Now if its painted on, you're stuck with it unless you want to repaint.
12.6 @ 114.6 MPH
did he put it on to cover a paint line where he sprayed upto? probably.
Go back to your uncle and tell him to fix it...
________________________________________.
Still not low enough for a signature.
If he did use it to cover a paint line, you can always just replace it with a diff color. A flat black stripe would look good on black and be hardly noticeable.
12.6 @ 114.6 MPH
Twenty4z wrote:Go back to your uncle and tell him to fix it...
x2
It might be painted on, Painted on pinstripes are common anymore. If it's vinyl it's going to be fun peeling it off. They are tiny and rip every 2 inches. Use a heat gun.
