I haven't posted in here since I don't know when. I finally got these things working. This is the first place I look when something is wrong or I want to install something. Big Upz to Jbody.org.
6K White Amber Switchback 3157. I only had the resistors hooked up and they would not work. Last Monday I got a LED flasher from Napa, installed it and they worked.
F.Y.I. if anyone else wanted to get these. The LED Flasher and resistors I think did the trick. They are nice, do a search for switchback LEDs and you will see. Holla.
If using load resistors only, a pair of 6 ohm 50w will work if changing front or rear, a pair of 3 ohm 50w or four 6ohm 50w if changing both front and rear.
