Does anyone know if a Cavalier spoiler like the one on
the picture below fit on a sunfire 2003-2005 4 door
_______________________________________________________________
Kevin
2004 Sunfire sedan
Swap the trunks, all the same sedan to sedan
![](http://i17.photobucket.com/albums/b72/bLk99cAv/slvrblitsig1.jpg)
M62, 42's, ZZP 3", ZZP S3 H/E
214whp 190wtq
I know it would be easier but I want to keep my sunfire taillights but the bolts
on the trunk for the light of sufire/cavalier sedan 2003-2005 are not in the same place
Kevin
2004 Sunfire sedan
Kevin Charest wrote:I know it would be easier but I want to keep my sunfire taillights but the bolts
im not sure about the 03-05 but the 95-99 outer tails are the same on cav and fire
As far as I know, the bolt holes for the Sunfire tails and the 03 Cavalier tails in the trunk are the same... They fit on my Sedan.
i know that Cavy 2dr/4dr 2003-2005 and sunfire 1995-2002 have the same trunk but i heard that 2003-2005 sunfire have bolt at different place...
i dont have the same taillights as 1995-2002 Sunfire
Kevin
2004 Sunfire sedan
Kevin
2004 Sunfire sedan
Or my other choice is to put a 2000-2002 cavalier z24 trunk with this spoiler with the cavalier tailight but the rear end of my sunfire
will look empty. I dont know if this will looking good? I never see that...
Kevin
2004 Sunfire sedan
Would be interesting as I have thought of this also.. Did you decide to do it?
the_miker17(u kiddin) wrote:Kevin Charest wrote:I know it would be easier but I want to keep my sunfire taillights but the bolts
They mount the same. They are not the same tails though
You could always just cut off most of the studs on the center section and just use the 3 holes for the inner tails on each side.
Want hub spacers rear disk brackets or trailing arm bushings? Shoot me a PM.
![](http://img33.imageshack.us/img33/1419/decal4x7rbwn6.png)
many ways to tackle this. one just get a 03-05 lid and spoiler and swap ur sedan fire lights over fit the same. Two get a 03-05 spoiler and simply drill out the mounting holes into ur lid. No matter how u look at it the car and parts are GM, gm is notorious for repurposing parts. example, do u think they redsigned a whole lid for the 03+ cavs, NO just reused the one they had from the sunfire sedan. the 95-99 tails are diff(mount the same just styled diff) let me say, The 95-99 tails if u look on the outters have a square reflector as the 00-02 have a circle/oval, the inners 95-99 have a square back up lence where as the 00-02 have a circle half moon. Heck if you remove any 03+ trunk reflector or any sedan fire reflector and simply cover the holes you ar left with a 95-02 lid. So id say best fastest way just take the spoiler and drill the holes needed for the lid.
